WAP121 scheduler not working
jonathan.schott
Hi Community
I have two WAP121 with latest FW and I setup the scheduler according help and documentation to disable our secondary guest network in non-office hours. The problem is that it's still always enabled. I just can't make it work. Below are my settings, do I do something wrong or is this a known issue?
Prerequisites:
SNTP is configured, both WAP have the correct time
Scheduler is administratively enabled
Profile:
Configured one Profile for the guest network with two rules:
1. Weekdays / 9:00 - 20:00
2. Saturdays / 9:00 - 20:00
--> As I understood, that should enable access to the network assigned for Monday to Saturday between 9 and 20:00
Assignment:
Assigned the above profile to the guest network (VAP1)
Problem is that during night and even on Sunday, the guest network is still shown as enabled and also is visible/accessible on the clients.
Can somebody please help me?
Jonathan
mpyhala
Level 7
Level 7
Jonathan,
From the 1.0.0.3 Release Notes:
CSCtw47624
Symptom: After a factory reset, the scheduler does not work properly until the WAP device is power
cycled.
Workaround: After setting the scheduler for the first time, reboot the device and the scheduler
will function properly.
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap121/release/notes/Release_Notes_WAP121_321_1_0_4_4.pdf
- Marty
Edit: After reading the full release notes, it appears that this bug should have been resolved. I still recommend a reboot.
jonathan.schott
Thanks for the hint. However, the device has been power cycled multiple times afterward and still, the scheduler does not work. Any other idea?
Jonathan
