Hi there,
I have purchased 6 WAP125 for our office.
I've set them up on the 5ghz only, POE, assigned them all the same SSID with the same password and updated the firmware to 1.0.4.3
My issue is when adding the 5th one it will connect for a bit and then drop. Light will go solid green. We've tested this with different WAP's to rule out a faulty one. We've tried different network cables and ports on the wall. It seems to be once that 5th one is in place it does not want to function properly.
I've also go them in a DHCP reservation so that the statically assigned IP's will never be used by anything else.
I looked online to see if there may be a function limiting the number of WAP125's on a single network but could not find anything.
There is ample distance between each AP, about 30-50ft per unit. currently the web access portal is saying the unit is not connected to the internet but it's it showing in the FindIT app and I can ping it.
Can anyone shed some light?
