WAP150 Guest access
LAB77
Hello there,
Need some help to setup a separate SSID for guests? We have a WAP 150.
Basically, we have one SSID for business use. For guests or those with BYOD we want them to be able to use internet but, not connect to LAN devices. So ideally, have them connect to an SSID called GUESTS, or similar.
We have the WAP 150 connected to a switch (Netgear), connected to a SonicWall SOHO.
Thanks for your help (beforehand).
Iliya Gatsev
My name is Iliya Gatsev from Cisco Technical Support Team.
It is possible to set up Guest SSID on WAP150.
It will be good to call our support line and open a support case.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
