Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
hi, I created a schedule for the 2,4Ghz module to turn it off by night. Somehow this effects the 5 Ghz module. Once the 2,4Ghz turns on the 5 Ghz clients cannot connect anymore. For instance if I browse on my Iphone for available Wifi connections I c...
Hello everyone, about week ago I installed Cisco WAP150 and found strange effect, - sometime (often) SSH session to other devices on my LAN freeze if I connect via this AP but works normal if use AP from other vendor.I tred test ping, but don't have ...
I have 4 AP's wap321 3 of them joined the cluster but 1 is not joining any suggestions ?
Hi,How to firmware upgrade EPC2425 router?
I have a WAP 571 and after setting in up etc, there doesn't seem to be any option of seeing client statistics etc, eg RSSI. I am able to find who is connected. I have also noticed there is no option to tweak any RSSI for roaming. Or am i not looking ...
Replacing a WAP551 with the new WAP581, installation seemed straight forward then ran into a snag. The 551 running ping tests normal latency to wan ip addresses after installing the 581 running the exact same settings as the 551,and tried dhcp, if i ...
Hello,First of all, i hope this is the right place to ask my question.I have a problem with a Aironet 1242 (1240 series) device.The device is PoE and when i boot it receives an IP address from DHCP server. So far so good. The aironet is not connected...
Hello,we have WAP150 Access Points, to separate traffic we want to use additional WLAN id with separate VLAN.The AP is configured, WLAN1 with VLAN1 works, devices on WLAN2 with VLAN2 get IP Adress but cannot ping or open internet websites. Have teste...
Dear i purchase two WAP371 recently, i want setup guess network to separate staff and guess, WAP371 did support this function without firewall config? and i found WAP371 timeout shortly, how can i change the time for timeout? finllay question, i saw...
hi i need to explain my problem 1st. which is i have AP syslink WAP 300N its already installed in our office since 3 or 4 yearsnow i have many complains from users that the internet is not stable its some times down and get back up again the internet...
hi all i need to ask about the following brands which one is better and fast without issues , if any one use it and recommend for me : what about WAP121 ? what about WAP150 ? what about WAP125 ? what about WAP131 ? or if any one has good brand ...
I work for a Library as the only IT/Network associate. The library's WiFi consists of two Aironet 2600 AP's plugged into ports 3 and 4 of a WLC 2504. It's been a while, but I believe it originally set the AP's up as a pass-through. After recover...
Hi, I'm just wondering does anyone experiencing slow or unstable connection with WAP121 after upgraded the firmware to 1.0.6.7? It seems ever since the upgrade, the WiFi speed seems slow down or connection isn't stable. I've tried reboot the access...
I'm trying to reuse three of these older adapters.The reset described here -- https://www.youtube.com/watch?v=Shd5kuhMmww&t=6s does not allow me to sign in afterwards. The firmware notes note a bug where you cant sign in.I dont know of a good way t...
