10-07-2020 09:58 AM
Hello, I hope somebody has a solution for the issue I am facing.
I have 2 WAP150's, both with firmware 1.1.2.4, and I am not able to save a specific change. Under Wireless > Radio > Advanced Settings > Legacy Rate Sets I can unselect rates that I don't want to use. When I click the Apply button then nothing has been saved. So, when I refresh the page then all rates are selected again.
Is there a way to get these changes saved? Is this a bug in the webservice?
I tried several webbrowsers (Edge, Chrome, Firefox) but all give the same result, the changes in the Legacy Rate Sets are not saved.
Thanks!
10-09-2020 08:02 AM
I was able to test in the LAB with WAP150 and the same version of the firmware 1.1.2.4 and also not able to modify the Legacy Rate Set values on 5Ghz radio. On 2.4GHz it works. Please confirm if you are facing the same issue only on the 5Ghz band?
Martin
10-09-2020 12:53 PM
Dear Martin,
I can confirm that for the 2,4GHz radio it works, but for the 5GHz radio changes cannot be saved.
Thanks for your support, hopefully we will have a resolution for this soon.
