WAP150 sometimes not authenticate\accociate clients
Dear all hello!.
Trying to solve a problem, would like to hear some reccomendations from community...
we have two WAP150 AP's connected to Mikrotik router, and after some uptime good working (3-5 days) (Radio 1) interface stops working. This can happen on any of two AP's randomly.
Featurure is that this happen only on RADIO 1 interface (2.4gHz)  RADIO 2 (5gHz) continue working well always. In addition,during this problem the signal level is jumping (ALL SSID's on Radio 1).
Nothing special in LOG is reflected. (please find attached)
Also please have a look on the screenshot "Associated Devices" tab shows devices trying to connect but not authenticated and associated.
Reboot solve the problem untill it randomly appears again.
Active Firmware Version: 1.1.0.9
ktonev
It sounds like this issue may be related to wireless interference on the 2.4GHz radio since there is no problem with the 5GHz radio. Do you have any other sources of wireless signal on the 2.4GHz radio in close proximity to the WAPs?
There are no other Radios  in close proximity to the WAPs. There are some, but their signal is weak. WAPs located on -1 floor (basement)
Still experience this problem.. still cant find solution(
