WAP200 to WAP200e
davelainen
After the firmware updates the connection bewteen the WAP200 and 200e was perfect.
Recently things have not been great. The WAP200 will drop its connection with the 200e.
- a reboot of the 200e will usually bring back the connection
OR
- Re- applying the saved config to the 200 and power cycling both units will work
OR
-  The WAP200 unit will be inaccessble forcing us to reset the 200 back to Factory Defaults then re-applying the saved config.
What could be wrong?
0 Replies 0
