WAP2000 Admin console not accessable
Reggie.Wheeler
I'm having an issue with our WAP2000 access point.  I had to reset the access point and now I can't access the admin console.  I've set a static IP address just as I did when I first set it up. Now when I browse to the 192.168.1.245 in my browser it just displays an Authentication error.  Need some help with this please.
Reggie.Wheeler
Ok so here is what needs to be done.
If you are using the WAP2000 you may(will) have some issues if you are trying to configure your device you must have it attached to a router that has 192.168.1.* class c IP Range.  If not you will have some issues.  Once you have that part you can then move on to accessing the admin console.
If the router is wireless or wired make sure that DHCP is turned on so that you can insure that you will recieve an IP address in the same range.  With that done connect to the Router not the WAP and wait for the connection to be established.  Once that is done you can then browse to either 192.168.1.245 or http://192.168.1.245.  once inside set the WAP to accept web support this way no matter what IP it gets once configured you can access it.
