Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi all,Does ' s give an HowTo for WAP4410N and Radius Server Win2k9-R2?Thanks for each assistance.Stefan
Hi Gang,I know the AP541N can support the 7921 phone but all the documentation I've read assumes the AP541N is registering the phone with a UC500 system. I was curious if there would be any problems using this AP with a 7921 at a remote site (881SRST...
Purchase the unit from Amazon and installed it in December. Device worked perfectly with excellent coverage for approx 14 days then I got a call from the location stating that they where not seeing the SSID. Power cycled the unit and still nothing. ...
HII purchased two linksys wrv210 routers and the firmware seems to be damaged. The dhcp server for the router is not working and even if i configure a static ip address on my notebook. I still can access the router via the web interface. I have alrea...
I have a AP541N connected to a UC560. We are currently configured for Wireless Voice and Data. We have added a Guest VLAN, but don't see where in CCA to secure the VLAN from accessing the other other two default VLANs. Any help would be appreciate...
Hi allWe have a UC500 with 3 access points AP541N. We need to move around the building so we use wireless voice with 7925G phones. All works fine except when the phone needs to change from one AP to another. We lost connection for a small interval of...
I could not connect a WET200 (newly bought) to our WPA-enterprise/TKIP wireless network.Can anyone tell me what was wrong? Does WET200 support WPA-enterprise? Please help!Thanks a lot.
I'm trying to bridge two buildings with two WAP200E. The connectivity is fine, but I'm only able to get one VLAN through the bridge. That is the default VLAN 1 wich is untagged. I have two additional VLANs wich is tagged. I can not get these two thro...
I can't access the configuration page for my WAP2000 at 192.168.1.245. The WAP2000 is connected to a Netgear RP114 router on port 1. My wired PCs are all connected to a Netgear GS108 switch on router port 4. I can't ping the WAP2000 from any wired...
The issue I am having is this when moving throughout our building my laptop will not switch between AP’s unless it loses its connection with its existing AP then it will see the other AP that is closer and connect to it.For example, I start at one en...
I have an AP541N deployed. I am getting a log message that says: "deauthed from BSSID 00:21:29:00:c7:e0 reason 1" I have searched Cisco.com for documentation that would tell me what "reason 1" means, but have not found the answer. The Administation...
Hi guys!In April the company where I work will move to another place. The manager, for budget purposes,would like to build a free-cable network, based on wireless.The situation:We have about 50 computers, connected via cable to a switch. There is not...
I want to make a bridge with 2 WAP4410N access points.But what is the totaly distance that the access point can make to have an good connection in an open area?So example:one WAP4410N in a house (near a window) and the other in a house (near a window...
Dear Sir Please advise if the autonomous Cisco WAP4410N Wireless-N Access Point could be managed using CiscoWorks WLSE Express Best RegardsMohammad Salah
HiI know that there was couple of similar topics but none of them seems to be solved.We have 6 AP's WAP200, all of them configured with the same SSID and diffrent channels. When i walk with a terminal or a laptop it looses couple pings when roaming b...
User | Count |
1 | |
1 | |
1 | |
1 | |
1 |
