I have a WAP200E and it seems like this is the Lemon of all APs. Its connected via PoE, mounted outside is a pretty covered area with Antenne is a good spot.
It seems like it will loos its connection to the Network, though still allow clients to Connect Wirelessly. I cannot Access it via its Ethernet Port from the LAN unless I power Cycle it. Then at some unknown time I loose connection to it again. It comes back for a while, then I lose it again.
From the Releae notes it looks like Firmware 2.0.5 is out, though the latest on the Support site is 2.0.3.
Any Tips to get this guy working again? I love the External AP, when it works I can get Signal on most of the 2 Acres. I's hate to have to put Range Extenders in all my outbuildings...
