WAP321 cannot update firmware - web-interface timeout
wap321_usr
Community Member
Hello all,
I have a Cisco WAP321 AP with firmware 1.0.5.3. The download speed is around 0.1 Mbit/s even though the wire has 100Mbit up/down. The device has PoE and is connected to an HP Procurve 1905-PoE. I have other devices connected to this switch and they work just fine.
I've read a few threads about other people having this exact same problem and that a firmware update did the trick.
I have downloaded firmware 1.0.6.2 and I'm attempting to do an upgrade but unfortunately the web-interface always gives me a timeout.
I would really like to upgrade the firmware and have the download speed back to normal.
What can I do here?
jbattist
Level 4
Level 4
Hello wap321,
       You can try going to Administration > HTTP/HTTPS Service>Session Timeout and change it to 60 minutes and then test the upgrade.  Hope this helps.
I managed to do the update but it was a PITA. I had to connect a power supply to the AP and it to my computer (I did a factory reset beforehand). Only then did it actually initialize the update. Considering this is a Cisco, I am profoundly disappointed in this product.
Nevertheless, it worked. I will test the wifi speed with different settings tomorrow.
Such a PITA this device.....
