Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi there.I am having a hard time setting up an ACL on a WAP321. The customer basically wants an open access point, that only allows access to one specific website. Is there any way to specify a domain name with an ACL on the WAP321? Thanks
can you please help.we bought about 20 of these APs, they do get DHCP assighn IP but refuse to join the or find a WC. any Ideas why. *Mar 1 00:03:46.639: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP ...
In my home I have two Cisco wap121. How do I set them up to work through out the house? I want one on ththe first floor and one on the second. What settings are needed so both will work with each other. I want to be able to use what every access po...
Hi, We have a customer with a number of AP561, there are 2 SSID's configured, IP are supplied to the devices in each network via dhcp, one is handled by a small business switch and the other is handled by a customers windows server. The issiue is tha...
Hi,I have a WAP321 here, which is running at firmware version 1.0.3.4. The E-Mail Alert setup works for me, meaing I receive notification E-Mails from the Access Point.I am wondering however, why those E-Mails are blank, meaning, I only receive heade...
Hello,The company I currently work for consists of a warehouse and an office that are connected to each other. The approximate area of the entire premise is 3600m^2 or ~39000 square feet with the area covering a rectangular shape. With the current wi...
Hello, I'm looking for advice on a recent, deployment of 5x clustering 351 wap's install. The new waps really fitted the bill for this project/property, witch 10 years ago, luckily when built had a few cat5e cable's installed.As a two part project, w...
I bought the three cisco ip 303 voip phones ,,,,and the wireless-G bridge for phone adapters, Is it compatible with windows 8 ??I need to install the wireless bridges to 2 of the phones , I couldn't get the installation done , any ideas or installati...
Dear,We have two WAP321 with firmware 1.0.53 running in a cluster. The AP's are configured as 5 ghz - n channel 40. Channel bandwidth 20 (tested with 20/40 : no difference).The connected PC's are running fine. The situation with the iPad's has deg...
Hello,My client current has a Cisco ESW520 24 Port POE switch. We are looking for a new Wifi Access point for the network that is more of a commercial grade rather than the average home wifi ap. They want it to cover the entire building and work of...
HiIn our setup with 3 Cisco WAP-321 - client's get disconnected randomly.That with the latest FW and locked channels.Top Drop is: STA is leaving IBSS or ESSI thought - that with Cisco products,- we would get a steady & stabile solution.
We have several Wap321 access points that are running fine. However, the person that configured them is no longer available and we do not have the user ID or password that he used. We do not want to reset all these devices. Is there any way to find t...
