09-11-2014 02:03 AM
We are receiving lots of drop outs on our WAP321. My line manager is asking why I insisted in getting a Cisco unit, and I'm getting it in the neck from all the users, so I'm reaching out to the community for some help - I hope you can assist.
Nobody is further than 8 metres from the AP which is desk mounted in an open office (there are 10 of us in total).
I have checked with a wi-fi analyzer and fixed us on channel 9, there are only two other networks in range and they are on 5 and 12 respectively.
The logs say the clients are disconnecting for multiple reasons:
reason 6: Class2 frame received from non-authenticated STA
reason 8: Sending STA is leaving BSS
reason 4: Disassociated due to inactivity
reason 3: STA is leaving IBSS or ESS
And my favorite:
reason 1: Unspecified Reason
I am happy to provide any information settings etc you think may be causing our woes. Any help will be much appreciated.
Thanks in advance!
09-11-2014 01:40 PM
Please refer
https://supportforums.cisco.com/discussion/11966786/wap321-random-disconnecting-clients
09-12-2014 03:36 AM
Thanks salodh but I have read that along with every other article I could fine in the Cisco forums relating to WAP321 and disconnecting clients. I have tried the changes, reset and and suggestions in that post but they did not resolve the problem. Thanks for reaching out though.
09-26-2014 12:56 PM
También tengo este problema con mi equipo y lo malo es que ya se me termino la garantía, me gustaría saber si alguien sabe de un método para determinar si el problema es de hardware.
I also have this issue, but I have no warranty anymore, could somebody tell me about a technic or software to check the hardware status of this device, in order to figure out if the problem is a but configuration?.. In advance thanks. CISCO WAP 321
09-26-2014 12:59 PM
