WAP321 Disconnection due to reason 17
johnsteel1
Hi I'm looking to indentify the cause of an error 17 disconnection
Time Stamp  Severity  Service  Description
Mar 27 2014 12:21:21  info  hostapd[1301]  The wireless client with MAC address a0:88:b4:4a:26:b8 has been successfully authenticated.
Mar 27 2014 12:21:21  info  hostapd[1301]  wlan0: WPA STA a0:88:b4:4a:26:b8 pairwise key exchange completed (WPAv2)
Mar 27 2014 12:21:21  info  hostapd[1301]  wlan0: IEEE 802.11 STA a0:88:b4:4a:26:b8 associated with BSSID 78:da:6e:7b:21:90
Mar 27 2014 12:21:21  info  hostapd[1301]  wlan0: IEEE 802.11 Assoc request from a0:88:b4:4a:26:b8 BSSID 78:da:6e:7b:21:90 SSID mpro100
Mar 27 2014 12:21:21  info  hostapd[1301]  wlan0: IEEE 802.11 STA a0:88:b4:4a:26:b8 deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Mar 27 2014 12:21:21  info  hostapd[1301]  Station a0:88:b4:4a:26:b8 had an authentication failure, reason 17
Auto 5g Channel
Single Point Disabled
No Bridging
error 17code Element in 4-Way Handshake different from (Re)Association Request/Probe Response/Beacon frame
mohabdel
Hi John,
It sould like you enable WPA Personal and WPA version 2 personal.  and your laptop with intal wifi card not like that.  Please change secuirty to WPA v2 only and monitor connection 24 hours.
Moh
johnsteel1
Hi with only WPAv2 and AES enabled we are still getting drop outs that is affecting all the users connected to the access point at the same time.
The only other change was to use a fixed channel in case the AP was changing channels and disconnecting stations
Apr 7 2014 10:38:30infohostapd[1433]wlan0: WPA STA 5c:f8:a1:a6:87:83 pairwise key exchange completed (WPAv2)
Apr 7 2014 10:38:30infohostapd[1433]wlan0: IEEE 802.11 STA 5c:f8:a1:a6:87:83 associated with BSSID 78:da:6e:7b:21:90
Apr 7 2014 10:38:30infohostapd[1433]wlan0: WPA STA a0:88:b4:4a:2d:7c pairwise key exchange completed (WPAv2)
Apr 7 2014 10:38:30infohostapd[1433]wlan0: IEEE 802.11 STA a0:88:b4:4a:2d:7c associated with BSSID 78:da:6e:7b:21:90
Apr 7 2014 10:38:28infohostapd[1433]wlan0: WPA STA 08:11:96:65:cc:00 pairwise key exchange completed (WPAv2)
Apr 7 2014 10:38:28infohostapd[1433]wlan0: IEEE 802.11 STA 08:11:96:65:cc:00 associated with BSSID 78:da:6e:7b:21:90
Apr 7 2014 10:38:27infohostapd[1433]wlan0: WPA STA 08:11:96:65:c2:18 pairwise key exchange completed (WPAv2)
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 08:11:96:65:c2:18 associated with BSSID 78:da:6e:7b:21:90
Apr 7 2014 10:38:27infohostapd[1433]wlan0: WPA STA 08:11:96:65:ca:c4 pairwise key exchange completed (WPAv2)
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 08:11:96:65:ca:c4 associated with BSSID 78:da:6e:7b:21:90
Apr 7 2014 10:38:27infohostapd[1433]wlan0: WPA STA a0:88:b4:4a:26:b8 pairwise key exchange completed (WPAv2)
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA a0:88:b4:4a:26:b8 associated with BSSID 78:da:6e:7b:21:90
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 5c:f8:a1:a6:87:83 deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA a0:88:b4:4a:26:b8 deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 08:11:96:65:cc:00 deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Apr 7 2014 10:38:27infohostapd[1433]Station 5c:f8:a1:a6:87:83 had an authentication failure, reason 17
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA a0:88:b4:4a:2d:7c deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Apr 7 2014 10:38:27infohostapd[1433]Station a0:88:b4:4a:26:b8 had an authentication failure, reason 17
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 08:11:96:65:c2:18 deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Apr 7 2014 10:38:27infohostapd[1433]Station 08:11:96:65:cc:00 had an authentication failure, reason 17
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 08:11:96:65:ca:c4 deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Apr 7 2014 10:38:27infohostapd[1433]Station a0:88:b4:4a:2d:7c had an authentication failure, reason 17
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 88:1f:a1:b6:82:a8 deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Apr 7 2014 10:38:27infohostapd[1433]Station 08:11:96:65:c2:18 had an authentication failure, reason 17
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 88:1f:a1:b6:82:a8 deauthed from BSSID 78:da:6e:7b:21:90 reason 4: Disassociated due to inactivity
Apr 7 2014 10:38:27infohostapd[1433]Station 08:11:96:65:ca:c4 had an authentication failure, reason 17
Apr 7 2014 10:38:27infohostapd[1433]wlan0: IEEE 802.11 STA 88:53:2e:89:b5:7a deauthed from BSSID 78:da:6e:7b:21:90 reason 1: Unspecified Reason
Apr 7 2014 10:38:27infohostapd[1433]Station 88:1f:a1:b6:82:a8 had an authentication failure, reason 17
Apr 7 2014 10:38:27infohostapd[1433]Station 88:53:2e:89:b5:7a had an authentication failure, reason 17
