Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gear Support page index - Contains ...
CoreyP319 by Cisco Employee
  • 3845 Views
  • 1 replies
  • 5 Helpful votes
Hi guysI have a WAP121 AP, and i want to be able to setup a guest SSID along with my full access SSID. The guest network should only be able to access the internet.I have the AP plugged into a single port on a Netgear GS728TP smart switch.I know i ha...
I need to setup a wifi hotspot for my customers at my café. The size of the café is about 100 sq metres, and max number of users is 100, though it is likely to be around 50 on normal days.Is a single WAP561 access point sufficient for my usage, or sh...
JohnTan00 by Community Member
  • 1617 Views
  • 2 replies
Hi Guyz, I am using WLC 2504 (Sysinfo given below), I created a new SSID on different VLAN, but when i used to connect to it while using previous SSID. Moving between two SSID is very slow. I have to disconnect my wifi then wait for 5 mint and then a...
Hi, I've searched these forums (it seems) exhaustively and found no answer to my particular issue.  The following configuration was functioning beautifully until I, in my infinite wisdom, decided to update the firmware on my RVS4000 and WAP4410n.  My...
kroberts2 by Community Member
  • 1286 Views
  • 2 replies
We have an AP541N that has been deployed to replace a Cisco 1200 AP (B/G radio).  The 1200 functioned perfectly in our environment.  The new AP541N on the other hand seems to work fine right after a reboot but immediately starts to degrade service.  ...
lucas4 by Community Member
  • 38653 Views
  • 86 replies
