09-08-2012 08:25 AM
How does this work? Do you have to make your own page or are there any "canned" pages to use? I'm assuming you put the appropriate UR, in the redirect section?
Solved! Go to Solution.
09-11-2012 06:29 AM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
Excellent question. There is actually a "canned" splash page for the the initial login to captive portal available in the device. The developers did allow room for it to be tweaked to fit customer needs. By this I mean, it allows you to add your own wording or to change some coloration of the page.
If you would prefer to go in a different direction, there is also the ability to do a redirect to a page of your own creation.
Hope this helps.
Eric Moyers
Cisco Network Advanced Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
09-11-2012 06:29 AM
Hope this helps.
Eric Moyers
CCNA, CCNA-Wireless
1-866-606-1866
02-28-2013 02:25 PM
In addition to what Eric Moyers stated, the links provided below are articles that explain how to customize your own splash page and redirect to a page of your choice.
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=3036
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=2937
Hope this helps.
Thank you,
Nnennaya Udochu
Prabhjit Bagga
Small Business Content Development Engineers
04-17-2016 02:47 AM
yes, i know... 4 years ago, but i have to try :
Eric says:
"If you would prefer to go in a different direction, there is also the ability to do a redirect to a page of your own creation."
Do anyone knows how can i set redirection without included cisco's captive portal ?
