wap321 url redirect, auto authenticate
Sage Major
I want to setup my wap321 to not go to the Captive potal login page ,I want everyone to be authenticated automatically.  I just want them to be redirected to my home page the first time they try and visit any page.
I have the CP setup but I dont see any way to not request a user page and just redirect.
I am using the latest firmware.
Sage Major
I read some more about this I figured out the No login option
Under the CP instance I set Verification to Guest.
I  am still not getting the redirect
Under CP->Global Configuration->Captive Portal Mode is enabled
Instance configruration
name TBinstance
Instance id 1
admin mode enabled
protocol http
verification guest
redirece enabled
redirect url http://www.cnn.com
Instance Association
VAP0 (cisco-321)  TBinstance
Web Portal Custimation
Locale TBWebpaged
instance name TBInstance
Local Groups
Default only
Local Users
user name TB
password 111111
group name default
With these settings I am not getting the redirect.
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
I am attaching a guide for setting up captive portal. Let me know if this helps you.
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866 ext 601027
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
