Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi, I need enable WPS function on WAP4410N. Help says that this is possible with CLI command #set wps enable. But how I can connect to WAP4410N with CLI? Thanks for any suggestions.
I have a WAG320N router and want to use my WAP4410N as a wireless repeater for it within a small, internal network using the same SSID for both.I have little experience in this and hope that there's a step-by-step guide to doing this - or perhaps som...
Hello,I'm setting up a wireless network for a small office with 25 people with approx. 15 on wirless at any time. The office is very long and skinny so I'm looking at a cluster of WAP321's. I'm hoping these will save a ton of money versus buying a co...
Hi,Does the WAP4410N support Dynamic VLAN assignment by means of 802.1x authentication?The reason why I ask this; I am able to configure a SSID on a WAP4410N with WPA2-Enterprise, in combination with 802.1x PEAP network authentication. I can succesfu...
Hi,I am trying to set up SSH/Telnet on a WPA2000 Wireless-G Access Point. I have looked for documentation but am unable to find any that says how to do this via the GUI, and I cannot see any obvious place where this could be. Has anyone manged to set...
Most WAPs we've used in the past have the ability to disable access to the WAP's management interface via a wireless connection. This greatly increases security when the WAP is being used to provide guest Wi-Fi access. Support suggested today that ...
Hi AllI have 3 WAP200e APs in a client site and I am having a problem with the signal between the APs and Motorola 9000 barcode scanners.The first one went in about 6 months ago and it worked fine. The client then asked for two more to be installed i...
Hi, I get the message "Firmware upgrade has failed. Please ensure that valid entries were specified in the required fields." when I try upgrade the firmware rootfs.bin over http/https. Someone an idea?I have downloaded the release 1.0.2.3 and 1.0.1.1...
helloi have Accesspoint WAP200 Modeliam trying to make repeater mode from other routers ( not linksys or cisco) but not works for me when try to connect to the network which repeated with WAP200 its trying to take ip then failed ( its like DHCP not w...
Hi All, I am not able to reload in Access Point and upgrade it to LAP.When ever I do that ,I receive error "magic number mismatch". My image upload is successful everytime but not able to reload that image.Please suggest me what I have to do fo...
Good morning,I've some troubles connecting my PS3 to my RV120W.Both router and PS3 have latest firmwares. They are connected wireless (distance is about 10 mt, signal is good).PS3 ip is in DMZ (connection doesn't work with only Upnp), and ip fragment...
Right now the Self-signed Certificate on my RV180W generates errors as it was issued to the MAC address instead of the current IP address. Could someone please provide me insrtucions on Generating a Self-Signed certificate (or 1 from my Windows Serve...
Hi all,I am dealing with a small network mixed with wired and wireless network.With wire network we are using ip address range- 192.168.1.0 255.255.255.0With wifi network we are using ip address range 10.168.1.0 255.255.255.0A network printer (HP la...
If I connect my WAP121 directly to my router, it works just fine. But when I connect it to my SG100D-08P switch I can see it but when I connect, I get "limited connectivity" and it cannot "identify". The switch is PoE and everything looks to be wor...
Hello everybody. We put in place 4 devices. Everything is working five (apple IOS6+ not obv...). So when somebody is connecting he have to read our agreement, enter is full name and check the box. (is not personnal session...)How can i have log his n...
