09-11-2013 02:02 AM
Hi.. I have configure my Cisco WAP321 and running ok rite now... I have Aztech Wifi Repeater and use it to strengh/extend my wifi signal but it cause problem on my wifi... cannot connect to my cisco ap... after reboot the WAP321 everything get back to normal... Can I now which brand/model of wifi extender/reapeater that compatible with this CISCO WAP321.. thanks...
09-13-2013 08:30 AM
Dear Customer,
Thank you for reaching the Small Business Support Community.
I'd suggest you another WAP321 so that you can take advantage of the WDS feature, please refer to page 90, chapter 5 of the admin guide for details;
You still can use the WorkBook Bridge feature for this matter (see page 93 on admin guide) even though I am not sure about what repeaters brand/models work best and I'd still suggest you another WAP321 so that you can have the Single Point Setup (see chapter 10) that provides a centralized method to administer and control wireless services across multiple WAP321 devices.
Please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
09-13-2013 12:34 PM
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
Currently the only supported configuration is with the WAP321 connecting with another WAP321 in order to use WDS. Within Work Group bridge it is possible to connect with non-cisco devices.
Eric Moyers .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
11-29-2017 05:56 AM
please when you answer give us a full guide solutions
how to connect two cisco wap321 with WDS bridge ????
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
