01-15-2020 03:00 PM
I have a cluster setup of two WAP371.......below screenshots of the config. disconnects clients every few days and won't reconnect until the AP is rebooted.
Log Message from AP 192.168.10.5
TIME Priority Process Id Message
Jan 15 2020 14:56:44 3 hostapd[12957] trying to update accounting statistics, station c4:65:16:e0:64:a1 not found
Jan 15 2020 14:56:44 3 hostapd[12957] trying to deauthenticate to station c4:65:16:e0:64:a1, but not authenticated
01-15-2020 10:31 PM
- Try disabling MFP on the WAP371, check if that helps.
M.
01-16-2020 06:28 AM
01-17-2020 04:59 AM - edited 01-17-2020 05:01 AM
Some general advise:
- Enable WPA2 if possible
- Disable WPA1(if possible) and more important, disable TKIP (it's cracked und unsecure)
- some devices might need to delete the WLAN profile and do a new connection
- Change 802.11b/g/n channel width to 20 MHz (not 20/40)
- Change 802.11b/g/n channel to 1, 6 or 11 (don't use any other)
Those changes will also allow you to use 802.11n speeds, which is disabled by having TKIP active.
01-22-2020 02:10 PM
None of these suggestions seemed to help. I have attached a log of the controller AP
Jan 22 2020 15:40:56 | debug | hostapd[1490] | station: 34:a8:eb:9d:3c:a2 deauthenticated | |
Jan 22 2020 15:36:34 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 15:29:34 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 15:29:28 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 15:16:17 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 15:16:11 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 15:09:56 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 15:09:55 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 15:03:55 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:55:43 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:55:36 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:54:30 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:54:26 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:53:24 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:52:18 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:52:13 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:51:56 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:51:12 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:49:56 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:49:49 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:49:31 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:49:25 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:49:12 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:49:05 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:49:05 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:48:56 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:48:50 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:48:40 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:48:34 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:47:58 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:46:24 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:45:53 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:45:50 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:45:45 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:42:36 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:41:30 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:40:24 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:39:17 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:38:22 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:38:11 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:37:06 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:36:32 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:36:18 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:36:00 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:35:31 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:35:30 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:35:04 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:34:54 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:33:57 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:33:48 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:32:42 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:30:34 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:29:28 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:29:20 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:28:22 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:27:15 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:27:14 | debug | hostapd[1490] | station: c8:09:a8:4e:31:e9 deauthenticated | |
Jan 22 2020 14:27:09 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:26:20 | debug | hostapd[1490] | station: 58:e2:8f:a5:34:3b deauthenticated | |
Jan 22 2020 14:21:03 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:21:00 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:13:19 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:13:13 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 14:07:04 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 13:58:36 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 13:58:35 | debug | hostapd[1490] | station: 14:95:ce:11:94:be deauthenticated | |
Jan 22 2020 13:22:41 | debug | hostapd[1490] | station: 94:53:30:0e:cc:84 deauthenticated | |
Jan 22 2020 14:54:24 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:54:24 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:51:50 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:51:50 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:46:18 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:46:18 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:45:50 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:45:50 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:38:19 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:38:19 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:36:11 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:36:11 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:35:02 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:35:02 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:33:52 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:33:52 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:29:14 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:29:14 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 14:27:06 | err | hostapd[1490] | trying to deauthenticate to station 58:e2:8f:a5:34:3b, but not authenticated | |
Jan 22 2020 14:27:06 | err | hostapd[1490] | trying to update accounting statistics, station 58:e2:8f:a5:34:3b not found | |
Jan 22 2020 13:23:12 | err | mDNSResponder | _csco-sb._tcp. service renamed from "RWD1-CLUSTER" to "RWD1-CLUSTER (2)" | |
Jan 22 2020 13:23:01 | err | mDNSResponder | _csco-sb._tcp. service renamed from "RWD1-CLUSTER" to "RWD1-CLUSTER (2)" | |
Jan 22 2020 13:22:59 | err | mDNSResponder | _csco-sb._tcp. service renamed from "RWD1-CLUSTER" to "RWD1-CLUSTER (2)" | |
Jan 22 2020 13:22:56 | err | mDNSResponder | _csco-sb._tcp. service renamed from "RWD1-CLUSTER" to "RWD1-CLUSTER (2)" | |
Jan 22 2020 13:22:48 | err | hostapd[1490] | trying to deauthenticate to station 94:53:30:0e:cc:84, but not authenticated | |
Jan 22 2020 13:22:48 | err | hostapd[1490] | trying to update accounting statistics, station 94:53:30:0e:cc:84 not found | |
Jan 22 2020 13:22:35 | err | hostapd[1490] | trying to deauthenticate to station 5c:f3:70:4e:16:35, but not authenticated | |
Jan 22 2020 13:22:35 | err | hostapd[1490] | trying to update accounting statistics, station 5c:f3:70:4e:16:35 not found | |
Jan 22 2020 13:22:34 | err | hostapd[1490] | trying to deauthenticate to station b0:6f:e0:31:e5:38, but not authenticated | |
Jan 22 2020 13:22:34 | err | hostapd[1490] | trying to update accounting statistics, station b0:6f:e0:31:e5:38 not found | |
Jan 22 2020 15:40:56 | info | hostapd[1490] | STA 34:a8:eb:9d:3c:a2 disassociated from BSSID 84:8a:8d:f5:f0:f2 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:40:56 | info | hostapd[1490] | STA 34:a8:eb:9d:3c:a2 deauthed from BSSID 84:8a:8d:f5:f0:f2 reason 4: Disassociated due to inactivity | |
Jan 22 2020 15:36:34 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:36:34 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 15:36:28 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 15:36:27 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 15:29:34 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:29:34 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 15:29:28 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 15:29:28 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 15:29:28 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:29:28 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 15:29:22 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 15:29:22 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 15:16:17 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:16:17 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 15:16:11 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 15:16:11 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 15:16:11 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:16:11 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 15:16:04 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 15:16:04 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 15:09:56 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:09:56 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:09:55 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 15:09:55 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 15:09:55 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:09:55 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 15:09:49 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 15:09:49 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 15:03:55 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 15:03:55 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 15:03:49 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 15:03:49 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:55:43 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:55:43 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:55:38 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:55:38 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:55:36 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:55:36 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:55:31 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:55:30 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:54:30 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:54:30 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:54:26 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:54:25 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:54:25 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:54:24 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:54:24 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:54:24 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:53:24 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:53:24 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:53:19 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:53:19 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:52:18 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:52:18 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:52:13 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:52:13 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:52:13 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:51:56 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:51:50 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:51:50 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:51:50 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:51:12 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:51:12 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:51:07 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:51:07 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:49:56 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:49:56 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 14:49:49 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:49:49 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:49:49 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:49:49 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:49:43 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:49:43 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:49:31 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:49:31 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 14:49:25 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:49:25 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:49:25 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:49:25 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:49:19 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:49:19 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:49:12 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:49:12 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 14:49:06 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:49:06 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:49:05 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:49:05 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:49:05 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:49:05 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:49:00 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:49:00 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:48:59 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:48:59 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:48:56 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:48:56 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 14:48:50 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:48:50 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:48:50 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:48:50 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:48:44 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:48:44 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:48:40 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:48:40 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 14:48:34 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:48:34 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:48:34 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:48:34 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:48:28 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:48:28 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:47:58 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:47:58 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:47:53 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:47:53 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:46:24 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:46:18 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:46:18 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:46:18 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:45:53 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:45:51 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:45:50 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:45:50 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:45:50 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:45:50 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:45:45 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:45:45 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:45:45 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:45:45 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:44:39 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:44:39 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:42:36 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:42:36 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:42:31 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:42:31 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:41:30 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:41:30 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:41:25 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:41:25 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:40:24 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:40:24 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:40:19 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:40:19 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:39:17 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:39:17 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:39:12 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:39:12 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:38:22 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:38:19 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:38:19 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:38:19 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:38:11 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:38:11 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:38:06 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:38:06 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:37:06 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:37:06 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:37:01 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:37:01 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:36:32 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:36:26 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:36:26 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:36:18 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:36:12 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:36:11 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:36:11 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:36:00 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:36:00 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:35:55 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:35:55 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:35:31 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:35:31 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:35:31 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:35:31 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:35:30 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:35:30 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:35:24 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:35:24 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:35:04 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:35:02 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:35:02 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:35:02 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:34:54 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:34:54 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:34:49 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:34:49 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:33:57 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:33:52 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:33:52 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:33:52 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:33:48 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:33:48 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:33:43 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:33:43 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:32:42 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:32:42 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:32:37 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:32:37 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:30:34 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:30:34 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:30:29 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:30:29 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:29:28 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:29:28 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:29:23 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:29:23 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:29:20 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:29:14 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:29:14 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:29:14 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:28:22 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:28:22 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:28:17 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:28:17 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:27:15 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:27:15 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:27:14 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:27:14 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:27:09 | info | hostapd[1490] | STA c8:09:a8:4e:31:e9 associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:27:09 | info | hostapd[1490] | Assoc request from c8:09:a8:4e:31:e9 BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:27:09 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:27:09 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:27:08 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:27:06 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:27:06 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:27:06 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b deauthed from BSSID 84:8a:8d:f5:f0:fa reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 14:26:20 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:26:14 | info | hostapd[1490] | STA 58:e2:8f:a5:34:3b associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:26:14 | info | hostapd[1490] | Assoc request from 58:e2:8f:a5:34:3b BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:21:03 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:21:03 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:21:00 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:21:00 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:21:00 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:21:00 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:20:54 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:20:54 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:13:19 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:13:19 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:13:14 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:13:14 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:13:13 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:13:13 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:13:13 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:13:13 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 14:07:04 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:07:04 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 14:07:04 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 14:07:04 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 14:07:04 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 14:07:04 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 14:07:03 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 14:07:03 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 13:58:36 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:f9 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 13:58:36 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:f9 reason 1: Unspecified Reason | |
Jan 22 2020 13:58:36 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:f9 | |
Jan 22 2020 13:58:36 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:f9 SSID RWD1-Guest | |
Jan 22 2020 13:58:35 | info | hostapd[1490] | STA 14:95:ce:11:94:be disassociated from BSSID 84:8a:8d:f5:f0:fa reason 8: Sending STA is leaving BSS | |
Jan 22 2020 13:58:35 | info | hostapd[1490] | STA 14:95:ce:11:94:be deauthed from BSSID 84:8a:8d:f5:f0:fa reason 1: Unspecified Reason | |
Jan 22 2020 13:58:35 | info | hostapd[1490] | STA 14:95:ce:11:94:be associated with BSSID 84:8a:8d:f5:f0:fa | |
Jan 22 2020 13:58:35 | info | hostapd[1490] | Assoc request from 14:95:ce:11:94:be BSSID 84:8a:8d:f5:f0:fa SSID RWD1-Techs | |
Jan 22 2020 13:55:06 | info | hostapd[1490] | STA 34:a8:eb:9d:3c:a2 associated with BSSID 84:8a:8d:f5:f0:f2 | |
Jan 22 2020 13:55:06 | info | hostapd[1490] | Assoc request from 34:a8:eb:9d:3c:a2 BSSID 84:8a:8d:f5:f0:f2 SSID RWD1-Techs | |
Jan 22 2020 13:24:42 | info | hostapd[1490] | STA b0:6f:e0:31:e5:38 associated with BSSID 84:8a:8d:f5:f0:f1 | |
Jan 22 2020 13:24:42 | info | hostapd[1490] | Assoc request from b0:6f:e0:31:e5:38 BSSID 84:8a:8d:f5:f0:f1 SSID RWD1-Guest | |
Jan 22 2020 13:23:00 | info | clusterd[1543] | AP with MAC Address "84:8A:8D:F5:F0:F0" and priority "1" is elected as Dominant AP | |
Jan 22 2020 13:23:00 | info | clusterd[1543] | Cluster management address "192.168.10.6" is installed. | |
Jan 22 2020 13:22:48 | info | hostapd[1490] | STA 94:53:30:0e:cc:84 associated with BSSID 84:8a:8d:f5:f0:f8 | |
Jan 22 2020 13:22:48 | info | hostapd[1490] | Assoc request from 94:53:30:0e:cc:84 BSSID 84:8a:8d:f5:f0:f8 SSID RWD1 | |
Jan 22 2020 13:22:48 | info | hostapd[1490] | STA 94:53:30:0e:cc:84 deauthed from BSSID 84:8a:8d:f5:f0:f8 reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 13:22:41 | info | hostapd[1490] | STA 94:53:30:0e:cc:84 disassociated from BSSID 84:8a:8d:f5:f0:f8 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 13:22:38 | info | hostapd[1490] | STA 5c:f3:70:4e:16:35 associated with BSSID 84:8a:8d:f5:f0:f8 | |
Jan 22 2020 13:22:38 | info | hostapd[1490] | Assoc request from 5c:f3:70:4e:16:35 BSSID 84:8a:8d:f5:f0:f8 SSID RWD1 | |
Jan 22 2020 13:22:35 | info | hostapd[1490] | STA 5c:f3:70:4e:16:35 disassociated from BSSID 84:8a:8d:f5:f0:f8 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 13:22:35 | info | hostapd[1490] | STA 5c:f3:70:4e:16:35 deauthed from BSSID 84:8a:8d:f5:f0:f8 reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 13:22:34 | info | hostapd[1490] | STA b0:6f:e0:31:e5:38 disassociated from BSSID 84:8a:8d:f5:f0:f1 reason 8: Sending STA is leaving BSS | |
Jan 22 2020 13:22:34 | info | hostapd[1490] | STA b0:6f:e0:31:e5:38 deauthed from BSSID 84:8a:8d:f5:f0:f1 reason 3: STA is leaving IBSS or ESS | |
Jan 22 2020 13:22:33 | info | hostapd[1490] | STA 94:53:30:0e:cc:84 associated with BSSID 84:8a:8d:f5:f0:f8 | |
Jan 22 2020 13:22:33 | info | hostapd[1490] | Assoc request from 94:53:30:0e:cc:84 BSSID 84:8a:8d:f5:f0:f8 SSID RWD1 | |
Jan 22 2020 13:22:28 | info | hostapd[1490] | STA 98:e7:f4:b3:b7:35 associated with BSSID 84:8a:8d:f5:f0:f8 | |
Jan 22 2020 13:22:28 | info | hostapd[1490] | Assoc request from 98:e7:f4:b3:b7:35 BSSID 84:8a:8d:f5:f0:f8 SSID RWD1 | |
Jan 22 2020 13:22:12 | info | dman[1063] | SSL certificate generated for Clusterd |
01-23-2020 08:37 AM
- Below are some further resources , which you may study for further analysis of the problem :
M.
01-29-2020 05:32 AM - edited 01-29-2020 05:34 AM
Hi everyone,
I have a cluster of 3 Cisco WAP 371, and exactly the same issue.
Still looking for solutions, after 18 months of use ...
Disable MFP , Disable TKIP , keep only WPA2 , change the PoE for PoE+ , disable 5 Ghz to keep 2,4 Ghz Only , disable bandwidth ...
Always the same issue, customers are loosing their Wifi Connexions and cannot get back. The only way is to Reboot the AP.
What the Heck with Cisco AP !
01-29-2020 07:41 AM
- Perhaps the 2.4Ghz environment is too crowded with bad stuff. You may want to do the reverse. Disable 2.4Ghz and use 5Ghz only.
M.
01-29-2020 07:51 AM - edited 01-29-2020 07:52 AM
Thanks for your quick reply,
I can't disable 2,4 Ghz , because we have a lot of people using old devices who work only with it.
Jan 29 2020 16:17:22 err hostapd[22187] trying to deauthenticate to station 98:10:e8:bf:9e:09, but not authenticated Jan 29 2020 16:17:22 err hostapd[22187] trying to update accounting statistics, station 98:10:e8:bf:9e:09 not found Jan 29 2020 15:15:03 err hostapd[22187] trying to deauthenticate to station 98:10:e8:bf:9e:09, but not authenticated Jan 29 2020 15:15:03 err hostapd[22187] trying to update accounting statistics, station 98:10:e8:bf:9e:09 not found Jan 29 2020 14:53:16 err hostapd[22187] trying to deauthenticate to station 00:9d:6b:37:10:db, but not authenticated Jan 29 2020 14:53:16 err hostapd[22187] trying to update accounting statistics, station 00:9d:6b:37:10:db not found Jan 29 2020 14:52:48 err hostapd[22187] trying to deauthenticate to station 00:9d:6b:37:10:db, but not authenticated Jan 29 2020 14:52:48 err hostapd[22187] trying to update accounting statistics, station 00:9d:6b:37:10:db not found Jan 29 2020 14:52:48 err hostapd[22187] trying to deauthenticate to station 00:9d:6b:37:10:db, but not authenticated Jan 29 2020 14:52:48 err hostapd[22187] trying to update accounting statistics, station 00:9d:6b:37:10:db not found Jan 29 2020 14:52:47 err hostapd[22187] trying to deauthenticate to station a4:fc:77:1a:70:5d, but not authenticated Jan 29 2020 14:52:47 err hostapd[22187] trying to update accounting statistics, station a4:fc:77:1a:70:5d not found Jan 29 2020 14:52:47 err hostapd[22187] trying to deauthenticate to station a4:fc:77:1a:70:5d, but not authenticated Jan 29 2020 14:52:47 err hostapd[22187] trying to update accounting statistics, station a4:fc:77:1a:70:5d not found Jan 29 2020 14:52:47 err hostapd[22187] trying to deauthenticate to station a4:fc:77:1a:70:5d, but not authenticated Jan 29 2020 14:52:47 err hostapd[22187] trying to update accounting statistics, station a4:fc:77:1a:70:5d not found Jan 29 2020 14:52:45 err hostapd[22187] trying to deauthenticate to station 38:ba:f8:07:48:88, but not authenticated Jan 29 2020 14:52:45 err hostapd[22187] trying to deauthenticate to station 38:ba:f8:07:48:88, but not authenticated Jan 29 2020 14:52:45 err hostapd[22187] trying to update accounting statistics, station 38:ba:f8:07:48:88 not found
01-30-2020 01:20 AM
- Try to use a fairly recent software release on the AP. If that doesn't help either and the problem lays in the area I discussed earlier (2.4Ghz-messed-up) , then you may have the option of testing with a higher-end ap model , which you could possibly obtain from Cisco or your re seller for testing purposes.
M.
01-30-2020 01:24 AM
My Cisco WAP 371 are running firmware 1.3.0.7 .
I will make test with 2.4 Ghz Disabled.
Thank you for your support .
Regards.
OVYA
02-03-2020 02:38 PM
Did that seems to reslove your issue when you disabled the 2.4 Ghz OVYA?
02-04-2020 06:54 AM
No, still have the issue.
01-07-2021 01:34 AM
I have struggled with similar problems for almost a year in my home and I'm about to throw the WAP371 in the trash bin.
What a pity. My experience with Cisco in the enteprise has been fantastic, e.g. L3 switches having uptimes of 7 years pushing hundreds of megabits constantly... But these Small Business WAP devices are simply not fit for purpose. Great GUI, online help, lots of options, but it often stops working after less than a week. Very disappointed.
01-07-2021 03:49 AM - edited 01-07-2021 03:50 AM
That likely seems to be a hardware problem so you can open up a ticket with the STAC which will troubleshoot and/or do an RMA.
Please reach out to STAC for your country based on the following contact details:
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Martin
