WAP4400N Firmware Status
m.ruggles
I have 2 WAP4400N access points, each has a different version of the firmware installed and one has options that the other one does not.
I have one access point running
1.2.17-ETSI
and one running
1.2.8
If I visit the Cisco site for firmware updates, I see that only one version of firmware is available for this access point... 1.2.14
This is quite poor for Cisco, I realize that Linksys is not Cisco's main area of business, but if you are going to provide
downloads for access points you could at least make sure that you have the latest version available.
Can you please state when the latest firmware for this device will be realeased.
83 Replies 83
gloomrider
Version 2 firmware was made available today for the WAP4410n.  Does anyone have an update on when we can expect to see similar firmware for the WAP4400n?
Thanks in advance.
According to this part of the Cisco site:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10047/end_of_life_notice_c51-512798.html
the WAP4400N will be end of support in 2011, and is already end of sale. Cisco does not tell its customer facing engineers about projected firmware release dates due to having the GPL approved. The best solution is to just check back periodically, or if your situation is such that you can't wait, call the Small Business Support Center and open a trouble ticket. The number is 866-606-1866.
Bill
Ha! valued partners indeed.
Thanks Bill
Based on this response (no new firmware for you because this product is EOL in less than two years), and the less than stellar reviews of the new WAP4410N firmware (new GUI, same bugs), I will be looking to other vendors for my small business Wireless Access Point needs.
Gloomrider
Not sure on the 4410N issues you are referring too. We had the wrong code posted for a bit, so possibly that is the reference? I believe 2.0.0.5 is doing ok. Check https://www.myciscocommunity.com/message/15753#15753
on the 4400N, there is no firmware, just becuase it's taking a while (I don't know why) not because the product is end of sale.
I hope the 4410N can meet your needs.
Thanks.
Hi Greg
I was pointing out that WAP4410N users have been waiting a long time for an update and it would seem that the wait is all about the rebranded GUI.  The release notes that accompanied the new WAP4410N firmware suggest than a minimum of known issues were addressed.  The WAP4400N users have even less to show for their patience.  All the user community wants is action.  A new GUI may meet some marketing-driven rebranding requirement, but it does nothing to reassure customers of a commitment to quality.  I have been a big fan of Linksys hardware for years now.  But my patience is wearing thin.  I have already begun to look at comparable hardware from other vendors.  Am I ready to jump the Linksys ship?  Almost.
No doubt a long wait! Unfortunately all I can do is apologize for that. Short version - we had to change some internal approval process and it overwhelmed the parties responsible. Poor planning and timing on our end. It appears this won't be an ongoing issue for future releases. The releases have been more than rebranding, I'm sorry that't not too obvious. I know too if you don't reset to factory defaults after the upgrade there seems to be residual issues. In addition, good news/bad news on forums, right. Someone can be having a lot of issues that are interference, etc and believe it's still an issue with the device. Wireless is particular a challenge here. I know I've had several 'bad wireless' experiences over the years that were really environmental and not device...Sorry not making any excuses here, just a reality sometimes.
As far as bug fixes. To me there have been MANY so I would hope most/if not all the issues you are experiencing have been resolved. Obviously this is 4410N specific. I know we had some recent file posting issues that also prevented some users from receiving the latest version.
Hopefully this helps address some of your concerns. Thank you for your loyalty, I know this transition has created some pain, but we should be in a better position going forward. Below are the bug fixes in recent firmware updates.
2009/5/18 v2.0.0.5
Based on V2.0.0.4.
Change List:
1.    Fix bug #7408: DNS restore fail after loading configuration.
2.    Fix bug #6926: SMTP server and syslog server ip address can't block some invalid ip addresses.
3.    Fix bug #7508: Warning message show error if set utilization threshold to blank.
4.    Fix bug #7422: HTTP Rediect URL can be fixed with HTTPS protocol by cli.
5.    Fix bug #7425: HTTP Rediect URL can be fixed with HTTPS protocol by SNMP.
6.    Fix bug #7401: HTTP redirect url can accept invalid ip addresses and if setting it to dut ip,it works abnormally.
7.    Fix bug #7516: WPA mode key including space can't be saved again.
8.    Fix bug #6802: Static ipv6 address can't block some invalid ip address.
9.    Fix bug #6601: set remoteucr command can set mac for WDS Repeater Mode.
10.    Fix bug CSCsz56657: Login page:  browser title bar should NOT display product model name.
11.    Fix bug CSCsz56664: Warning Message in Factory Default requires modification.
12.    Fix bug CSCsz66033: Adding Product Model name in the Browser title bar.
13.    Fix bug that Removing Bonjour feature.
2009/04/20 v2.0.0.4 Jick
Based on V2.0.0.3.
Change List:
1.    Fix bug #6926: SMTP server and syslog server ip address can't block some invalid ip address.
2.    Fix bug #6802: Static ipv6 address can't block some invalid ip address.
3.    Fix bug #6828: Setting wpa key to specified characters lead to gui error.
4.    Fix bug #6812: Disable wireless function, but wireless mode doesn't show disabled on the page of wireless status.
5.    Fix bug #6814: Radius server of connection control can be saved with default values.
6.    Fix bug #6788: setting basic wireless page will show error on GUI.
7.    Fix bug #6036: clicking "Cancel" button fail when ssid's name blank.
8.    Fix bug #6835: HTTP redirect url can't be setted like www.abc.com:80.
9.    Fix bug #6807: Invalid manual date can be settled.
10.    Fix bug #6808: No warning message if setting Beacon interval, DTIM interval, RTS threshold or Fragmentation threshold to blank.
11.    Fix bug #6796: The same mac address can be added in page of AP mode.
12.    Fix bug #6795: Radius server secret key cann't be clear if it was once settled.
13.    Fix bug #6069: Wireless client can't open internet web when Redirect URL with HTTPS as prefix.
14.    Fix bug #6831: There is an error when open GUI by HTTPS protocol at the first time.
15.    Fix bug CSCsy91481: Incorrect Copyright Notice in About page.
16.    Fix bug CSCsy91484: Content Area title name change - Basic Wireless.
17.    Fix bug CSCsy91490: Content Area title name change - Security.
18.    Fix bug CSCsy91495: Content Area title name change - Connection Control.
19.    Fix bug CSCsy91498: Content Area title name change - Advanced Wireless.
20.    Fix bug CSCsy91501: Container Node name change in Wireless -> Advanced.
21.    Fix bug CSCsy91507: Page background is NOT fixed in Firefox 3.0.7.
22.    Fix bug CSCsy91510: Control Buttons are NOT LEFT-aligned.
23.    Fix bug CSCsy91513: MAC Address title name in AP Mode page.
24.    Fix bug CSCsy91516: Username display at the header is malfunction.
25.    Fix bug CSCsy91519: Error checking in login page.
26.    Fix bug CSCsy91527: Inconsistent Feature Name in the Title bar and in the Navigation Pane.
27.    Fix bug CSCsy91530: Inconsistent title name in "Basic Setup" Help page.
28.    Fix bug CSCsy91531: Inconsistent title name in "VLAN and QoS" Help page.
29.    Fix bug CSCsy91569: Inconsistent feature name in Titlebar across all GUI page.
30.    Fix bug CSCsy91593: Content Area title name change - Config Management.
31.    Fix bug CSCsy97530: GUI fails to redirect to default IP Address.
32.    Fix bug CSCsy97532: In System Perfomance page, Wireless Connection displays incorrectly.
33.    Fix bug CSCsy99105: Disabling wireless interface will erase previous SSIDs settings.
34.    Fix bug CSCsy99185: Wireless mode in Wireless status page display incorrectly.
2009/03/30 v2.0.0.3 Jick
Based on V2.0.0.2.
Change List:
1.    Change Linksys to Cisco in the HTML source files.
2009/03/20 v2.0.0.2 Jick
Based on V2.0.0.1.
Change List:
1.    Improve Bonjour function to meet the new spec: add control for every service type; add hdVersion in DNS TXT record field; add all Bonjour support for Web GUI, SNMP and CLI.
2009/03/13 v2.0.0.1 Jick
Based on V2.0.00.0.
Change List:
1.    Fix Bug #6116: SNMP Trusted Host static IP can't be setted by SNMP tools at the first time.
2.    Fix Bug #6024: ipv6address and ipv6gateway can't be setted by snmp.
3.    Fix Bug #6493: The serail number of WEP key can be setted different with the default transmit key.
4.    Fix Bug #6028: redo upload fail after the first upload file.
5.    Fix Bug #6191: WAP4410N compatibility is very bad with WPC4400N(Marvell).
6.    Fix Bug #6509: NTP server by Manual works fail.
7.    Fix Bug #6629: DUT crashed if the number of CMC emulating STAs was more than 3.
8.    Fix Bug #6612: CLI command snmpmanagemode and snmptrapmode not match to GUI's any feature.
9.    Fix Bug #6610: WdsVlanList should be deleted in MIB file.
10.    Fix Bug #6609: VlanQoSTable settings can't be setted by snmp.
11.    Fix Bug #6599: Disable wireless function, the other basic wireless settings shouldn't be edited.
12.    Fix Bug #6598: There is an error on Wireless Basic Settings web page.
13.    Fix Bug #6590: Delete button on the page of legal ap list worked abnormally if not selecting any ap entry.
14.    Fix Bug #6587: SNMP help file word error.
15.    Fix Bug #6582: Valid HTTP redirect url issue.
16.    Fix Bug #6572: Vista client setting dut WEP security mode by WPS failed.
17.    Fix Bug #6501: No warning message popped up when setting invalid value to key Renewal for wpa-psk or wpa2-psk.
18.    Fix Bug #6479: The valid length of username and password didn't accordant on login page and management page.
19.    Show message changed from linksys to cisco for upnp and mib description.
20.    Bonjour function is reworked for following Linksys' spec.
21.    Update GUI copy right date from 2008 to 2009.
22.    Firmware version format changed from 2.0.00.1 to 2.0.0.1 in web page.
2009/02/20 v2.0.00.0 Jick
Based on V1013.
Change List:
1.    GUI is rebranded.
2.    Support DHCPv6 Client.
3.    Support bonjour protocol.
4.    Support double-byte SSID.
5.    Improve wireless client list.
6.    Change the default host name based on MAC address.
7.    Change the default ssid from "linksys-n" to "ciscosb".
8.    Firmware version format changed to 2.0.00.0.
9.    Update wireless driver to LSDK_7.1.3.70_AP83FUSAtheros.
10.    Fix bug:[0006165] SSID Broadcast option be changed to disable as default optin when fix ssid2/ssid3/ssid4.
11.    Fix bug:[0006191] WAP4410N Compatibiity is very bad with WPC4400N(Marvell).
12.    Fix bug:[0006186] intel4965 A/G/N can't connect to AP which security is WPA/WPA2-AES.
13.    Fix bug:[0006184] WPC600N(Broadcom) connect to AP with wpa/wpa2 fail in RF1-shielding room.
14.    Fix bug: [0006035] WDS Wireless Client/Repeater mode don't work when "Allow wireless station to associate" optin disable.
2009/01/13 v1013 Archer, Jick
Based on v1012.
Change List:
15.    Fix bug:[0003621] The log file can not be saved
16.    Fix bug:[0003620] There is no warning information when save the same MAC in the Connection control List
17.    Fix bug:[0003619] The 2 Mac address can't be saved at the same time when cut one Mac to paste to another Mac.
18.    Fix bug:[0003608] The SSID 1 can not save 1,2and3number
19.    Fix bug:[0003595] When you fix a invalid ipv6 gateway in the blank ,the page will be closed after you click the Savesetting button
20.    Fix bug:[0003398]The channelbandwidth default value is not consist with the setting in the SNMP manager.
21.    Fix bug:[RD] mail server and http Redirect URL check error.(when input  http or https)
22.    Fix bug:[RD] when set wireless truck priority vlan id error.
23.    Fix bug:[RD] when set 11n only Cli & snmp cann't set wep or Radius.
24.    Fix bug:[RD] GW/DNS can set some invalid value
25.    Fix bug:[RD] UC/UR wireless apply destroy interface error.
26.    Fix bug:[RD] When DHCP Server and GateWay is different.DUT get GateWay error.
27.    Fix bug:[RD] Mib file: RTS Threshold (1~2347).
28.    Fix bug:[RD] When change Host name. syslog sent to Syslog notification server Host name show error.
29.    Fix bug:[RD] SNMP Trusted Host IP check. End IP less start IP
30.    Fix bug:[RD] Radius Server IP can set space
31.    Fix bug:[RD] Cli & SNMP IPv6 check strictly
32.    Fix bug:[RD] SNMP 802.1x supplicant get name & password error.
33.    Fix bug:[RD] Cli VlanDefault help error
34.    Fix bug:[RD] editcfg TimeZone cann't to update
35.    Fix bug:[RD] SNMP device name show error.(mib-II, Cli, editcfg)
36.    Fix bug:[RD] SNMP & Cli emailaddress check strictly
37.    Fix bug:[PA] In editconfig file IPv6 mode cann't restore
38.    Fix bug:[PA] In editconfig file NTP mode cann't restore
39.    Fix bug:[PA] In editconfig file Client/Repeater SSID cann't restore
40.    Fix bug:[PA] In editconfig file APMode Monitor cann't restore
41.    Fix bug:[RD]In editconfig file vap VLAN ID restore, VlanList restore error.
42.    Fix bug:[RD] When DUT set WDS mode and other AP connect DUT with UC/UR mode, Security set WPA or WPA2, some times WDS will be broken.
43.    Fix bug:[RD] In editconfig file wiless monitor Rogue Type error.
44.    Fix bug:[B0008081] SNMP: Device Name cannot be set or get in MIB II or in Sercomm private MIB via any SNMP management tool
45.    Fix bug:[B0008082] Help file with wireless mode(missing N-only, B/G-Mixed & B/G/N-Mixed)
46.    Fix bug:[B0008091] WDS: WAP4410N fails to receive correct 802.1p Priority (CoS) tagging over wireless bridging
47.    Update wireless driver to LSDK_7.1.3.66_AP83FUSAtheros
48.    Improve performance when working with Intel Centrio
49.    Improve working with wireless game adaptor WGA600N when streaming media
50.    Add KR SKU into country list.
51.    Fix bug [0006015]: CLI can't get ipv6 address and ipv6 gateway infomation
52.    Fix bug [0006019]: SNMP v1 & v2 can't set to APUT when GUI be fixed "Get Community" the same as "Set Community"
53.    Fix bug [0006020]: SNMP no block radius port 0 and 65536
54.    Fix bug [0006024]: ipv6address and ipv6gateway can't be setted by snmp
55.    Fix bug [0006025]: ipv6 Prefix Length can be setted as 999 by snmp
56.    Fix bug [0006021]: wep key can be fixed "172.21.98.238" or "10000" by snmp
57.    Fix bug [0006045]: IP address 10.0.0.35/255.255.255.0/10.0.0.1 fixed fail
58.    Fix bug [0006042]: Email server ip can be fixed with prefixal "http/https......"
59.    Fix bug [0006023]: There is an error show on AP Mode GUI when clicking check box "Allow wireless station to associate"
60.    Fix bug [0006165]: SSID Broadcast option be changed to disable as default option when fix ssid2/ssid3/ssid4
61.    Fix bug [0006121]: APUT can't get IPv6 IP address and gateway from WRVS4400Nv2 supply DHCP6 server
Hi Greg,
am I missing something? What gloomrider (and most of the followers of this thread) wanted is a release date for the WAP4400N model, not the 4410N model. If I download the latest 4400N firmware I still see 1.2.14-ETSI, and this is far outdated.
Is there any hope of getting a fresh 4400N firmware?
Sorry, yes we got off topic on the 4410N.
I do not have any update on the Firmware posting date for the 4400N
Please Greg answer to this simple question.You will intend to release a new firmware upgrade for the 4400N or not?
Elias,
As I've stated previously, I do not have an update on the relase of new firmware for the 4400N.  One of the product managers will update these thread when a definite date is known.
Thanks Greg.
I think a lot of us have moved on to other vendors by now.  I will keep an eye out for the satisfaction level of the WAP4410N users.  If it seems like the consensus is that it is a stable product, I might come back to the Linksys Business line.  Nothing personal, but this product line clearly is not a priority for Cisco.
P.S.: Did you know there are still plenty of WAP4400Ns out there in the supply chain?  Check with internet retailers.  Probably not a good purchasing choice at this stage.
Thanks.
I think Greg you are out of the topic...
I agree with the above, I think this thread is for the WAP4400N.
Having recently ordered 4 of these APs (admittedly, I didn't do much homework - typically, I relate Cisco to top quality) I am hoping I don't have the many issues that have been relayed in this and many other threads I've read online. I'll continue with the setup and update as I work through the install. Wish me luck.
Thanks for the lengthy reply.  Did you notice that the vast majority of "bugs" in the list were related to the implemenation of the new GUI?  I think you just helped make my point :-)
But let's get back to the topic at hand.  Can you show us the release notes for the upcoming new WAP4400N firmware?  No doubt many would be interested in knowning what's in it and when we might expect to see it.
Regarding your assertion of environmental issues, I have substituted other vendor's access points for the WAP4400N in the same environment and not had the same issues.  If you read the threads, it seems the symptom of the AP losing connection to all clients and not reestablishing until a power cycle is pretty common for the WAP4400N.  So if a different AP from a different vendor solves the problem, can it still be explained away as environmental or user error?
I sincerely appreciate the back-and-forth, Greg.  And I'm hoping that Cisco's answer to frustrated WAP4400N owners is not, "Buy a WAP4410N".
