WAP4410N and Radius Server Win2k8-R2, how?
StefanSab
Hi all,
Does ' s give an HowTo for WAP4410N and Radius Server Win2k9-R2?
Thanks for each assistance.
Stefan
gloidl
Hi Stefan,
1. Start the IAS services on your wins server
2.Create AD Group
3.Put users into that group
4.Allow access to users
5.Create policy and grant access
6.Add new raduis client and server and set password
7.Eanble wireless signal
8. Set SSID and security
9. EAP(PEAP) and disable validation of teh certificate
10. Enter credentials for Auth in front of Radius
regards
g
Hi Gunter,
I wonder if you could help me too, I have configured as you state, and domain machiens connect fine, however non-domain PCs and devices (iphones etc.) don't work.... I think the issue on PCs is step 9 - disable validation of the certificate, where do I do this in NPS? changing the setting on the client makes no difference.
As for iphones/blackberrys, they prompt for a password, any idea what this is/where I set it?
Thanks for your help
Ben
