08-04-2011 08:44 PM
We have one unit running with 'fw-2.0.4.2-K9' firmware version, connected to a Cisco SFE2000P Switch via P.O.E, it has 2 SSiDs (WIFICorp and WIFIGuest). Even it set up to work with wireless in mixed mode, all laptops (Lenovo, Dell) can connect only as 'g'.
>>>>> Is there some setting missing to work in 'n' mode?
* These laptops can use N mode in another place (like a Hotel).
tks,
Renato P
08-15-2011 08:58 AM
Even adjusting to 'N-Only', the AP is detected as 'BG' from other devices and speed cannot be more than 54Mbps. I test from iPhone4, Samsung Galaxy, Lenovo Thinkpad SL400 and Dell Latitude E5420.
* I´m using channel #10 to avoid conflict with neighbors
08-17-2011 10:53 AM
Now our AccessPoint works in ‘N’ mode. I followed the advice from Cisco support team to factory reset the unit and use the ‘Mixed mode’ with ‘WPA2-PSK’ as security mode and ‘AES’ as the Algorithm and use a pass-phrase without special characters.
* They also said that this combination (security mode and algorithm) is the only homologated to work with 'N' standard.
tks,
Renato P
