Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I know Airplay isn't meant to be done across vlans, but surely it should work with things on the same vlan. The 541N's are clustered and have WDS enabled. The wireless VAP's are on the same VLAN, and intervlan routing works. Airplay works if the iDev...
Recently I bought a wireless router CISCO DPC3925, and would like to know whether this device can support wireless printing from my 2 laptops anywhere within my home. I hope someone can advise me on this issue. Currently my DLink DIR-655 can help me ...
I previously had successfully set up a VPN connection that allowed my computer (Windows 7 Professional) to connect to a remote server. Last week, we had to reset our Lynksys WRT54GL wireless router, after which the VPN connection doesn't work anym...
I have two WAP4410Ns (about a month old) running 2.0.4.2. They both stop transmitting wireless traffic after about 2 days. The SSIDs (which are normally broadcasted) stop showing up and all wireless devices are disconnected. When accessing via th...
Hi,I have Cisco Linksys Wireless-G Broadband Router WRT54G device at my site to establish PPTP tunnel with PPTP server. The tunnel gets established, but i can see the remote peer name like ePPTP instead which we have configured in that device.Firmwar...
In this network we have a cisco wirelss POE router and three 4400N AP's. All wireless AP's and Router have the same SSID and password. All devices have a static LAN IP address.My problem is when I joing a new device - specifically a printer - I have ...
I have two of these units setup as wireless bridging between two offices across a parking lot (about 25 yards, straight LOS, no obstruction). I am having a lot of problems with one or the other units suddenly stopping to respond. Looking around initi...
Hi all!We have more than 50 wap 200 access points. In our configuration we use wpa2-enterprise security mode with radius server. And use latest firmware(2.0.2.4). All works good, but after random time period (2 hours - one day) wifi access with wpa2-...
We have an existing Citrix Security Gateway and Web Interface that works fine within our wired network and is accessible via internet connections outside of the office -- all of our Citrix apps are accessible. We recently installed a Cisco 2100 wire...
We are experiencing issues when we flashed from 2.0.2.1 firmware on our Cisco Small Business WAP4410n to the recently released 2.0.4.2. This is a brand new unit that we received. After flashing from 2.0.2.1, if the SSID Broadcast is set to "Disabled"...
Looking for a Cisco, low-cost power injector solution to push the WAP4410N. Network is all cat6 and the AP is 100ft away...Thanks, MarkI'm long on Cisco - I believe in the future...
A couple of questions about the AP541N:1. Does anyone finally have these installed and working properly, especially in a clustered environment? I have read so many comments about slow performance, no performace, bad coverage, etc... They sound like...
HiI just got 3 AP541, the reason for getting this was the dualband...but has anyone gotten this AP to actually give both 2.4 and 5 GHZ at the same time???I have in my other office a Asus RT56, it costs about 1/3 of the cisco and this supports both 5 ...
I just recently replaced an older linksys pre-N router with a RV 120W. I thought this would be a good choice as a more professional router. I installed this router last week and things seemed to be working normally for web browsing, though I was re...
Hi:I recently adquired an AP541N Version AP541N-K9-1.7(2) and found that it has telnet and ssh ports open and cannot find a way to block access through this ports.SSH and TELNET console are linux, it looks like a customized linux distro. I dont like ...
