WAP4410N issues after firmware update
BenSchmitt
I have 2 V02 4410Ns that after I updated them from 2.0.1.0 to 2.0.7.8 they no longer work properly. They show static IP even though it is set to automatic, and the wireless mode shows Disable, but shows b/g/n if you look under wireless status. I tried resetting to factory, I tried a 30-30-30 reset. I even tried the 2.0.6.1 firmware and still get the same results.
serials are
ser1523066x
ser152304yz
BenSchmitt
Interesting enough, I loaded 2.0.2.1 and all functions returned.
I will try to update it one version at a time to see if I lose the functions again.
