Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
CoreyP319 by Cisco Employee
  • 1365 Views
  • 1 replies
  • 5 Helpful votes
Hi! Recently I had to setup some good Wi-Fi coverage in a large flat located in a very old building, that is to say with huge brick walls (some are 70 cm / 2 feets thick with some iron structure inside ...). Long story short as I knew multiple antenn...
Didier_DN by Beginner
  • 1268 Views
  • 2 replies
Hi,After many changes in the WAP561 configuration, the WiFi speed (90Mbit/s) is now satisfied on Apple Iphone 6.We had maximum 18MBit/s and the speedtest was unstable/flack during the test with a "normal" setup (WPA-PSK2, 20/40mhz etc.). I have upgra...
deriksson by Beginner
  • 824 Views
  • 3 replies
Hi Guys, I just recently bought a second hand aironet 1140. Now i'm trying to set it up with 2 SSIDs each on a seperate VLANs. Somehow this doesn't want to work. On the switch to which the AP has been connected the port is setup as a trunk. On the sw...
r.korsten by Beginner
  • 426 Views
  • 1 replies
