WAP4410N mode AP with WDS
JaroJ2013
I have 4 WAP4410N mode AP with WDS.
WAP4410N drop the connection, and traffic on LAN is abnormal - sometimes overwhelm all LAN
Also communication betweene APs in WDS hang.
I try
Regards firmware 2.0.7 and also 2.0.6  - is the same !
Jaro
en → sk
firmware
podstatné meno: mikroprogramové vybavenie
mpyhala
Level 7
Level 7
Jaroslav,
If the LAN port is connected to a 10/100 port, please reduce the LAN port on the WAP4410N to 10/100 as well so it will negotiate properly. Regarding the WDS issue, are there interfering networks in the area?
- Marty
The problem is, that first AP loop with the last AP. Solution is - configure APs to "cascade" :-)
In first AP in the WDS give address to second, in the secon AP in the WDS give address firts and third, ...
Then the last will not loop with the first, ...
For me this was the solution
Jaro
