I have a simple wireless network that works fine, except for one room where the signal is too low. So I purchased a WAP4410N to use as a range extender. would you please provide the exact settings that are need to set this up? I have tried many, many different configurations, and I can't get it to work properly. In particular, it will not give me an IP address and therefore won't connect. Also, is it important to use the SAME SSID name? or better to use a different name so as not to confuse the two signals (base unit vs repeater (4410)). Appreciate your advice
