I have several WAP4410N access points distributed through our plant and office. One recently started giving trouble: the signal is strong, but the data transmission is terrible. I'm getting slow data transmission and high packet loss when I connect to it via its wifi signal. If I connect to it via a different WAP (through its wired port) it works perfectly. The problem unit is mounted near the ceiling and nothing has moved to change potential interference.
I have tried:
- different channels
- firmware update
- rebooting the unit
The firmware update may have made a slight improvement, but not enough. Any other suggestions, or is this unit toast?
