Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hi,I have a Cisco WAP4410N-A access point in my office, and has started to not recognize wireless devices trying to connect with the correct Pre-shared Key. It is configured as; Network Settings: Static IP IPv4, IPv6 is disabled, Wireless Mode: B/G/...
Dear all,Does anyone know how many access points per cluster setup are actually approved? 8 Access Points or 16 Access Points are supported? And how many active users?A) On the Cisco Product Website & Cisco Datasheet is given:Single Point SetupYesNum...
Dear All,The problems I describe affect all our WAP371 networks. We have a total of 4 whose networks (all with Single Point Setup). In every network there are between 2 and 6 access points. (All APs running with latest Firmware 1.1.2.3). We fulfil al...
Does anyone have any expertize or experience in whether to mount these small business Wireless Access Points vertically or horizontially The mounting location is under a wood floor in a long, thin building with all the clients above the WAPs. Thanks ...
Hello, I am setting up a Cisco WAP561 access point with a captive portal. I have the captive portal configured so the user only needs to enter an email address and then click the checkbox to accept the acceptance agreement in order to connect and pro...
HiWe have a medium sized site with 4 WAP200's on. These are configured to use different channels and all 4 are hard wired into the LAN. They have firmware version 2.0.6.0-ETSI on. 1 SSID is present, all 4 are set-up (I hope!) correctly with WPA2 secu...
Hi together,I have 12 WAP4410N (1 per location) with the same wireless configuration in our branch offices.Two SSID's VLAN1:Office (WPA2-Enterprise with RADIUS Authentication), VLAN2:Guest (WPA2-Personal PSK).Everything was working fine, but...after ...
Where did the WPS 'soft button' and configuration detail go on the WAP561?There is no WPS Setup under the Wireless menu.
Hi, We're using Cisco WAP561 access points to get our thinclients (Dell Wyse) onto the wireless corporate network. We're using Microsoft NPS as our radius server.When the WAP561 has the newest firmware 1.1.2.3, the Wyse cannot connect to the network....
Dear Sir, i bought one access point then we configured as Wireless Client/Repeater but wireless connection disconnecting and connecting after a short whilei tried 4 more different ADSL and different IP range ADSL model showing same. so please advic...
I have several Cisco 541N WAP running in my environment which I manage with CCA. I have now upgraded to Cisco 561N WAP, and I was wondering if there is a better management software out there I could use. Looking for ideas.
DHCP fails to issue addresses in dual subnet environment. Please see attached.
hello, i have one RV110W router and i need configure this with WDS, but when i want check the option "Allow wireless signal to be repeated by a repeater", this is gray and i can´t select it.Can you help me?thank you regards
Hello everyone.My client has a WAP321 Wireless N POE AP. It is connected to port g0/2 on an ESW-520-24 cisco switch. I have a Cisco 5505 firewall with an unlimited user base license. Is it possible to setup a guest network that is on a differe...
