WAP4410N Time and Date Problems - Are you (Cisco) serious?
torsten2
I cannot set die date time correctly because the selection of the year supports only up to 2015 !!!
Are you serious?
Switching to NTP is not working!!
Dan Lukes
You (should) know what to do:
September 29, 2015: The last date to receive phone support as part of the product warranty. After this date, all phone support services for the product are available with additional charges or support fees.
You considered not to buy extended support for the device, isn't it ?
pippoplutoao
Hello, probably he knows what to do otherwise he will not write here...
He shall probably have trouble to find latest firmware to update the device as me. Where May I find the firmware for the not more supported apparatus? Thank You. Ciao
Hi There,
My name is Nikola Butlev and  I'm a Cisco Engineer.
Please try to configure NTP server.
To do that go to :
Setup/Time, check "Automatically" set time zone, enable "User defined NTP server"
try with this NTP server IP : 194.207.34.9
Then you should restart the AP and you will see the time and date will be up to date an accurate.
In order this to work you should be on latest firmware version which unfortunately can't be downloaded anymore since WAP4410N is phased out.
Sometimes NTP  server  takes at least a  few hours to get synchronized.
