Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello i has a Cisco partnership in the past that was cancelled but now i am trying to return to but everytime than i go in the Partner Self service Cisco Registration have an error than cannot allow me to continue, the error is showed in the Screens...
I have a 140AC and when trying to update the firmware from within the AP UI, I select cisco.com, I get the following error when trying to check for an update:DNS: IP Address Not FoundThe problem is that I cannot find anywhere in the setup to define D...
Hello everyone,I created two WLANs ( one for internal use and the other for guest). Tagged each network to an specific VLAN. I can see both SSIDs being broadcasted, but the issue is that the guest SSID is getting the wrong ip addressing , it getting ...
I have a 145AC access point and 3 142ACMs. Above message appears when Cisco Business Wireless App launches. I'm guessing this is caused by the recent change of Bell Giga Modem. 145AC is connected to a Trendnet TPE-TG160g POE switch.
I couldn't install 3 Cisco Business APs(cbw240ac) at the same time. Those Aps are in the same subnets of ISP Router's DHCP Scopes. Firstly, I configured First APs as SSID-AP1. Then it's working properly with its SSID-AP1. Then I configured 2nd APs as...
I have purchased 30 cisco business 240AC devices, but I review the datasheet, it shows max number of Access point is 50, recommended up to 25, can I setup them more than 25? or any suggestions?
Hello,I have a question regarding Cisco Business 150AX. I want to set up 802.1x authentication (using a RADIUS/NPS server) with dynamic VLAN assignment.I noticed that there is a limitation of 16 VLANs, but I couldn't find anywhere if this limitation ...
Hi how can i save statisk ip adress?I tried too much but its not working, i want to write statisk ip adress.
Cisco 240AC Access Point requires DHCP only??can i assign static IP address to internal AP and management IP ?
Firmware 10.4.2.0 for CBW150AX / CBW151AXM has been released, but I can't find the release notes anywhere. Can someone provide a link?ThanksMaurice
Hello to all,I would like to understand the CBW150AX Wifi access points.I am in the process of setting up my infrastructure, but something is bothering me.Why cisco has set up a system of two IP for these AP. One for the administration and another fo...
Hello!I can log in Cisco 240ac from (https://ciscobusiness.cisco ) if I connect on the same WiFi and there is DHCP protocol.but in another place, how can you log in Cisco 240ac Access Point without internet (without connection on the same WiFi) . I w...
Hi!I have Cisco Business 240ac Access PointMy question is can I connect AP with different switches or it must be available as special switches?(For Poe Port I Can Fix Business Poe Injector)
Hello,Does the 150AX support WPA3-OWE (Enhanced Open)? It's essentially an 9105AXI (ap1g8) with a modified version of EWC, correct? The 9105AXI does support OWE, but I can't find anything about the 150AX.We currently use 1815i APs with Mobility Expre...
I bought 2 Cisco WAP581 wireless APs. I am having a problem with the wireless going offline after a day or two. My Windows 10 laptop comes up and says there is no internet access after 24 hours. From the wireless laptop I cannot ping the WAP581 from...
