Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
I am sorry that you are experiencing issues with your WAP4410N. What I understand is that you have 9 WAP4410N's and that they are configured as below:
1) same SSID
2) wap2 mixed mode
3) channel auto
When you move around your wireless network area you get disconnected from the network.
First I would not put your devices on auto. I would make each one a static channel. Do you have other wireless networks in your area? Have you done a scan to see? One tool that I use is InSSIDer, it is a free program you can download from the Internet.
If after this you still have issues staying conected it would be worth calling in an opening a case so that someone could work directly with you to help resolve your issue.
Eric Moyers .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
