Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
hi,I've configured the 321 device, it's working fine for browsing.the problem I'm having is when I'm connected on the wired network I can watch an entire youtube video but when I'm on wifi on the 321 device the video at some point ...
Sir,Any body help me,i have Wap 4410n number of 9 Access point , we are configure and mount all of AP when i move all area then my network was disconnected ,i have configure bellow setting without controler are sugest me which controler i used,1) ...
MyWAP321 is dropping connections at least once a day since upgradiing to firmware 1.0.1.10. before the upgrade I had no problems and I have another WAP321 with firmware 1.0.0.3 that never drops connection. Is anybody else having this problem since up...
Hi team,I just wanted to crack my friends SSID password. (WPA2 Authentication).Is tat possible over tools like Aircrack-ng ??I bet him that i wil do soon..Please help me out guys.Nithin
Hello everybody.I am wondering if there's a way to create an admi user (let's call it "lobby admin") on the WAP321 which only has the rights to create/modify/delete local guest users. I wouldn't want to give full admin rights to the receptionist or w...
Hi All,We have 9 AP541n's in a cluster. There are two in an area where there is a high concentration of devices (high being potentially 50-ish on an intermittent basis when Parliament sits). We believe there is only about devices 10 trying to connect...
Hello to all,I am planning to setup a new WLAN using WAP4410N Wireless N Access Point. Is it possible to manage the AP using 4404 WLAN controller ?I need to buy arround 42 AP for covering the entire building.Regards,Aslam
I have a Wap200 in a community library environment and wish to set up a pubic open SSID and a private (secure) SSID using two VLANs with trunking to a CISCO RV180W router to force the traffic to be separate and yet allow internet access for bot...
Does anyone idea regarding the 'power' used by the 'radio' from this unit? 200mW? 300mW?I was reading the DataSheet but that information is not provided.https://media.cnetcontentsyndication.com/FTP/ContentCast/cisco/inlinecontent/wireless/wap/cnet_wa...
Why can't I turn off CCMP (AES) on the WAP321?I purchased this as a replacement for an older NetGear access point but now I cannot use it as I can't disable CCMP.I have some point of sale terminals which ONLY work with WPA and TKIP. Although I can d...
Dear,I have 3 WAP321 that worked normally for 5 months. Today one of them meet problem after my power of/on issue, these APs use adapter, not PoEafter power off and come back, I waited for 20 minutes but have no wireless signal as before. I checked ...
Hi there,I recently installed 6 wireless access points (WAP70) in a cluster for one of our clients.I have a company wifi configured and working correctly, im having a problem with setting up a guest wifi.I can see anywhere where we can issolate the t...
Looking to set up QOS on a RVS4000 to give a machine priority over others. Under the QOS tab, I click on qos set up and I can asign the port a 1-4, 4 being top priority. Is that it? What should I set the other ports to ? Seems almost to simple and I...
I am setting up a wireless network for a remote office. I am using a WAP321 and 4410N as a repeater.Can anyone point me to documentation on how to configure this topology? I know it's done with WDS. Any pointers to documentation or tips would be much...
Hi there,A counterpart of mine was asking what the antenna pattern is in the WAP321's and also how exactly they should be mounted. We can't seem to find the antenna patterns anywhere. Can somebody please post this in for for us? Thanks! ...
