WAP561 Guest Network
Hello
I need help with configuration of me new WAP561 , i created guest ssid and configurated captive portal with local authentication. It works fine but i need to isolate guest from company network. In our company network we use SG300 and SG500 switches with vlans and our router is Opensuse. I can create a new vlan for guest network with only open internet but how to configure WAP561 to work with 2 vlans ? I need to have 2 vlans and 2 ssid  working on WAP561, one for employers and one for guest. Plz help!
Jorge Obregon
if you have already the two vlans working fine onn the switch you simlpy add the guess vlan on the wireless network section on the access point  and specify that it´s going to work with that other vlan
Hope this help
