I have been looking to utilise the above authentication using a PAC file.
This is the system used by one of our clients. Although Cisco aironet 1300
series supports this, they are a good deal more expensive as a solution.
My question to see what your thought are is whether a device like this WET200
would ever be able to support this type of authentication with the likes of a firmware
upgrade? I know it's not worth holding your breath on, but the unit had originally
been purchased since cisco compatibility was a prerequesite. Only once we went
to setup did it become apparent as to the authentication method they used.
TIA
Andrew
