WET200-WET200 Bridge not passing DHCP Requests
nickpmuir
We have setup a bridge between two of our offices using two WET200's in adhoc mode.   Everything is connected fine and the signal strengh is good.   All traffic pass's over the bridge correctly but DHCP requsts/replys seem to be failing to traverse the bridge.    Our DHCP server is hosted on site A and the computers on site B fail to obtain thiers IP's from the dhcp over the bridge requiring us to use static IP's.
Firmware is currently the latest.
Has anyone managed to resolve this issue?
Nick
David Carr
Level 6
Level 6
Mr. Muir,
What version of firmware are you running on the wet200's?
If the latest, have you downloaded a fresh copy of the 2.0.3.2 and backed up your configs/ reflashed the firmware/ factory reset the device/ and reloaded the configuration.
I would try this on both devices and let us know if your still having the same issue.
