Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Bought a month or 2 ago, configured and installed as our public access point. Worked well except for locking up weekly. A few weeks back, I lost all connectivity with it. It will get power, but no wireless and no Ethernet lights on the front. I attem...
Hi,I've setup several VPN gateways and one Cisco gateway to our Juniper SSG140 with no issues, until today. We purchased a WRVS4400N and I'm trying to configure it to connect to our Juniper firewall, as a "dial-up" connection. I can get it to work if...
I have 3 WAP200 wireless-G access points.I have one set up as an APthe other two are set up as repeaters to the main AP.My question is Do I need a lan connection to each repeater ?also, do I need to create SSIDs for all three? & if so, do they need t...
History:I have 4 WAP4410N Access Points setup in a sorority house, one for each floor. The access points they had before were D-Link 2.4GHz POE APs. The reason for changing the access points was a lack of wireless coverage in the house. About 2 weeks...
Dear Friends,I am in search of a access point with below specification, so please let me know that which model has this functionalities.. Wireless Access Point: * No of port should be 10Base-T/100Base-TX Ethernet * Standard should be IEEE 802.11g, IE...
Hi. Having a problem getting WAP4410 working using RADIUS authentication for security. We have it configured for RADIUS for connection control as well as security. It passes the connection control - I can see the everything passes there in the RADIUS...
Dear All I have 6 WAP4410 Access points and am asked to configure it to support wireless roaming But no configuration examples on how to configure Roaming, can anybody tell me the steps to configure the access points to support roaming taking in cons...
Hi all,I have a few questions.Is it possibly to create VPN tunnel between ASA 5510 and SR-520w?If it is, does anyone here knows the VPN throughput of SR-520w?I'm not able to find it anywhere on Cisco website nor google.I'm trying to decide to get eit...
For years I have received occasional complaints about users being dropped from WiF and then reconnecting like a minute or two later. I wondered what tools people on the Forum used to troubleshoot this transient problem. Cisco APs like the 1200 don'...
I am trying to find a way to login to our wirless access point. I have a Aironet 1130AG series wireless router. I have the ip address. It is a POE device so i dont have a power supply for this device. When it is on I can see the Wireless Network but ...
Hi everyone!!!!!I have wireless 7921g phone. when i tried to access my messge button or service it display url is not configured!!!!!!!!!!!!!!!!!!i tried try to solve this problen since last 2 weeks but no luck!!!!!my IP phone service url is url serv...
I recently bought and installed a WAP4410N access point (using PoE) and it's running stable. I was able to access the web-based configuration by using the IP address of the AP (something like 192.168.0.184, coming from the DHCP of my router). However...
Hi All,I have a problem connecting router to internet. I try to connect with other router Netgear WPN824, Linksys WRT54G, Allied Telesyn AT-AR220E and with this working without any problem.I have static IP but I need PPPoE connection with username an...
I have an intermitant issue getting a DHCPaddress when using a Cisco Wap 200. Sometimes i can get an address but most of the time my devices fail.This happens with / without WPA or WEP
