10-05-2017 03:03 AM - edited 03-21-2019 10:47 AM
hi,
I have two access points (wap4410n) , I need to configure them to work as pear to pear.
how can i do it ?
thanks
Solved! Go to Solution.
10-08-2017 10:10 AM
This topology is more.often referred as Point-to-point and yes, its possible.
Basically you need to setup them in bridge mode.
Please, refers to the attached guide.
10-05-2017 01:38 PM
You may want to say peer to peer, right? Can you explain further?
10-08-2017 12:19 AM
Yes , sorry for the mistake.
I mean peer to peer, i tired to configure them but still not working correctly.
10-08-2017 09:00 AM
I see. But it is not clear yet why you intend to accomplish. Peer to peer is usually referred as two computers talking each other directly.
Can you explain what is your goal here? Maybe give an example?
10-08-2017 09:59 AM
Thank you Flavio for your replay,
I will try to explain what I need.
I have two buildings in front of each other, i can't make a network cable between them. I want to put one of the access point on each building and configure them as peer to peer, can (WAP4410N ) do this?
10-08-2017 10:10 AM
