날짜: 09-21-2011 08:14 PM
I need your help to send me wireless bridge settings for WAP 4410N.
I have purchased two sets of WAP4410N and i need this to connect as wireless bridge to use our external office users(1 or Max 2) which is just beside our office building to surf our internet and retrieve data from our main server.
Enclosed diagram for your understanding.
Await response and thanks in advance
해결되었습니다! 솔루션으로 이동.
날짜: 09-22-2011 01:32 PM
Hello Sudhakara,
Thank you for posting. You should set up AP1 in Access Point mode. Configure it as you normally would. Select the WDS setting and input the WIRELESS MAC address of AP2. Configure AP2 in WDS Bridge mode and scan for the SSID of AP1. Select it and the MAC address of AP1 should populate. Save the settings and the devices should now be bridged. The device that is plugged in to AP2 should be able to ping AP1 and the network. Please reply if you have any questions.
Hello Sudhakara,
날짜: 09-22-2011 02:01 PM
Are there any restrictions on any of these:
Is any of this any different if instead of an AP1 the router on the primary network is a WRVS4400N that AP2 is bridging too?
날짜: 09-22-2011 02:24 PM
Hi Matthew,
I can't think of any restrictions at the moment, although I wouldn't recommend changing the Advanced Wireless settings unless you know exactly what you are doing. The WAP4410Nv.2 should bridge a WRVS4400Nv.2 wireless network. Note that both devices should be hardware version 2 with the latest firmware. Other versions may or may not work well together.
날짜: 09-22-2011 05:47 PM
Hi Matthew Mascari and mpyhala,
Thanks for the info, i called cisco help desk and they instructed how to do.. so simple.
just need to key MAC address into each other and mac AP settings same.. its working good.
Thanks once again.
날짜: 09-22-2011 06:05 PM
What are your settings for:
I've found that several of the WPA2 options cause mine to fail and not remain stable for very long. Using WPA TKIP has seemed to work, but I would prefer to use WPA2 AES which so far always fails.
날짜: 09-22-2011 06:32 PM
Hi Matthew,
Settings as follow
B/G/N-Mixed
WPA-Personal
AES
날짜: 09-29-2011 10:01 AM
Now that it's been a week, how's the bridge working?
Anytime I try to use WPA2 or AES, my bridge needs to be reset every day. With TKIP, it's been fine longer, but that's not really what I want.
날짜: 09-29-2011 06:54 PM
Hi matthew,
Production @ near by office is not yet started. hence not started using yet. i will be start to use this after three weeks later.
날짜: 10-05-2011 05:46 PM
Hi Matthew,
you are right, connection always drop everyday.
Do you have any idea to encounter this ?
날짜: 10-06-2011 07:57 AM
I've got mine set to this now:
N
WPA-Personal
TKIP
Using the WDS-Bridge setting without any client associations.
This has been more stable for me. But, it's a huge disappointment.
Honestly, if I was using it for something more critical that required better security and stability, I would use a different product. In my case, it's in a house and I don't want to bother buying new gear and loosing the investment in the current products. But, for a real production use where the equipment cost wasn't really a driver, I would replace them with something else.
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
