[wrt54gl]: vpn connection fails with 800 code after wifi router reset
whocanhelpme
I previously had successfully set up a VPN connection that  allowed my computer (Windows 7 Professional) to connect to a remote  server. Last week, we had to reset our Lynksys WRT54GL wireless router,  after which the VPN connection doesn't work anymore.
The problem clearly lies with the WRT54GL router: I still can  establish a VPN connection with a wired connection that bypasses the  router, or on my home WIFI. OTOH, when attempting either wireless or  wired via the WRT54GL router, the message "port opened" is followed for a  long time by "connecting to [vpn address] using WAN Miniport (PPTP)",  next "connecting to [vpn address] using WAN Miniport (SSTP)", and  finally "connecting to [vpn address] using WAN Miniport (L2TP)". In the  end, an error code 800 is returned.
I'm no sysadmin wizard at all, and can't see what should have changed in the router configuration. Any help much appreciated, it's driving me crazy.
Ron
0 Replies 0
