WRVS4400N Wireless Security Settings question
Safar Safarov
Hi all,
I didn't find any informative description about the following options:
Wireless Isolation (between SSID w/o VLAN)
Wireless Isolation (within SSID)
Could you please explain clearly what does each option mean?
Thank you.
Safar Safarov
Have found the following description:
Wireless Isolation (between SSID w/o VLAN): When enabled, traffic on one SSID will  not be forwarded to any other SSIDs.
Wireless Isolation (within SSID): When enabled, machines on the same SSID  will not be able to see each other.
