1130AG connectivity problems
bryancella
Community Member
Was unable to assign IP through CLI. DHCP was assigned from Linksys RVS4000. I am able to access GUI fine. Basic default unsecured setup. Lights correct, but no connectivity.
Will the AP work with an internal IP or must it be static?
Do you have to use client ADU on every machine?
Is there any other connectivity tools or guides that may assist me better? I have followed all config guides on site.
Thank you in advance for any hair saving solutions.
jeff.kish
Level 11
Level 11
The AP will work with either DHCP or static addressing. You do not need to use the ADU to connect unless you're using a Cisco card, and even then you should be able to configure Windows or another third party client to use it.
If you don't mind, please post your AP configuration. We'll take a look at make sure that it's all configured correctly.
