1131 initial installaion issue
malberttoo
Level 3
Level 3
Gurus,
My goal is to configure my (2) 1131's the same, with (2) SSID's, one being visible and the other hidden. I would prefer to use the GUI if possible, but can do command line.
The visible SSID (named Public) is to have access to Vlan 15 only.
Problem: so far, I cannot see either SSID, though one is set to be visible.
Could someone please comment on the steps necessary to complete these tasks, and to the visibility issue.
-Michael
andrew.prince
Level 11
Level 11
Michael,
Have you assigned the SSID's to a specific radio or all radios?
Have you enabled the radios for transmission?
Have you configured the SSID that you want to be visbile to be broadcast in the beacon?
HTH>
jeff.kish
Level 11
Level 11
If you could post your current CLI configuration, I'm sure everyone would be able to help out very quickly.
Thanks for taking a look at my config...
Current configuration : 2938 bytes
version 12.4
no service pad
service password-encryption
hostname AP.NH1
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 ssid AkAeroWiFi
vlan 15
authentication open
guest-mode
dot11 ssid CscWP
vlan 907
authentication open
guest-mode
power inline negotiation prestandard source
username Cisco password 7 xxx
username admin privilege 15 password 7 xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 907 key 1 size 40bit 7 B04134C3F921 transmit-key
encryption vlan 907 mode wep mandatory
ssid CscWP
mbssid
station-role root
world-mode dot11d country US both
interface Dot11Radio0.15
encapsulation dot1Q 15
no ip route-cache
bridge-group 15
bridge-group 15 subscriber-loop-control
bridge-group 15 block-unknown-source
no bridge-group 15 source-learning
no bridge-group 15 unicast-flooding
bridge-group 15 spanning-disabled
interface Dot11Radio0.907
encapsulation dot1Q 907 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 907 key 1 size 40bit 7 FA1724FFA456 transmit-key
ssid CscWP
dfs band 3 block
mbssid
channel dfs
station-role root
interface Dot11Radio1.15
no ip route-cache
bridge-group 15
interface Dot11Radio1.907
no ip route-cache
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.15
no ip route-cache
bridge-group 15
interface FastEthernet0.907
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.30 255.255.255.0
no ip route-cache
ip default-gateway 192.168.0.2
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
end
Okay, a couple things I see right off the bat:
1. Only one SSID (CscWP) is configured on each radio. You'll need to apply the other SSID to the radio/radios as desired. In the GUI, simply go under SSID Manager, select the other SSID (AkAeroWiFi), and apply it to one or both of the radios by checking the appropriate boxes to the right under "Interface".
2. Currently, both SSIDs are configured for broadcast. In the GUI, go under SSID Manager, select an SSID, and scroll all the way to the bottom. Click the radio button for "Single BSSID", then use the dropdown box to select which SSID you want on broadcast.
I'm honestly not sure why running this configuration results in you not seeing any SSIDs being broadcast at all. I would expect the CscWP SSID to be broadcasting. Try making these configuration changes and let us know what you find.
Jeff
