1131Ag with powerdsine 6012 midspan
ron_mckie
I have 5 1131ag access points connected through a 6012 powerdsine midspan to provide POE. 2 of the units power up ok but the other 3 do not enable the radios. The 2 that are working are showing as drawing 8 watts but the other 3 are only showing 4 watts. They are all then connected onto a cisco WS-C3548-XL-EN running Version 12.0(5.2)XU of the os. The 2 that are working are on ports 8 and 9 on the cisco switch and the others are on ports 11,32 and 47. I have tried various combinations of the pre-standard and power-injector settings on the WLC4404 which I am using. Any ideas would be greatly welcome.
ron_mckie
Hi folks. I have disabled cdp on the switch ports and that seems to have solved the problem.
Good Info, Thanks!
Scott
