1140 and 4400 WLC detection issues.
scott_jackowski
I am not able to get our 4400 WLC to detect a new AIR-AP1142N-A-K9. (1140 series).
I have given the interface bvi1 an ip address and subnet mask that the controller should pick up.
The software version of the 4400 WLC is 7.0.230.0.
The software version of the AIR-AP1142N-A-K9 is C1140-K9W7-M.
I am able to connect older AIR-LAP1242AG-A-K9 units without any problem using the LWAPP commands but this unit does not seem to support these commands?
scott_jackowski
I obtained the Wireless LAN LWAPP Upgrade and Recovery Image for 1140 Series (c1140-rcvk9w8-tar.124-21a.JA2.tar) and issued the following command:
"archive download-sw /force-reload /overwrite tftp://TFTPSERVER/c1140-rcvk9w8-mx"
I receive the following error:
"%tar checksum error in fd 0 ERROR: Failed to extract from archive file tftp://TFTPSERVER/c1140-rcvk9w8-mx"
Is this the correct image?
OK, it worked, what are the commands to assign an IP, net mask, controller ip and hostname, I use to use the following but they do not seem to work.
AP#lwapp ap ip address
AP#lwapp ap ip default-gateway
AP#lwapp ap controller ip address
AP#lwapp ap hostname
  (optional)
When I use either LWAPP or CAPWAP I get a message stating "you should configure domain and name server from controller CLI/GUI"
Example:
capwap ap ip address
