02-03-2010 12:01 AM - edited 07-03-2021 06:28 PM
I encountered problems on 1142 AP heatmaps using WCS 4.2. I then discovered that WCS 4.2 Doesn't support the 1142 AP antenna that is why it is shown as "other". I then upgraded the WCS to 5.2.148 but still having the same problem wherein the antenna is "other". Then I decided to upgrade it to the latest version which is WCS 6.0.170 but still the problem exist and the antenna is still "other". I says when clicking the RF prediction that the other antenna is not supported for heatmaps, wether it is 802.11a/n or 802.11b/g. Need your help guys. Thanks!
02-04-2010 12:00 PM
What version of code are you running on the controllers with the WCS at 6.0.170.0? I assume you have entered AP placement and chosen the correct antenna or does it only offer "other"?
02-04-2010 03:28 PM
The WLC version is 5.2.
Yes I have done the AP placement but the antenna available on the 1142 is only "other".
02-12-2010 08:02 AM
What is the full version of 5.2 WCS you are running? What is the full version of controller code that is on the controller that has this 1142 AP?
02-12-2010 09:23 PM
I already have solved the problem. It seems that the problem was the Database. It may have retained the DB of WCS 4.2 when I upgrade to 6.0 that is why it still shows the AP antenna "other". I resolved it by configuring from scratch without restoring the 4.2 DB. Thanks for all your help
