1142 Color Codes
Hi ;
We have deployed many 1142 APs on a site.When i have checked color codes , some of thems LEDs are static green which we have expected.But some of them are not giving out any light.But from the controller menu i saw them active and operating.And i can connect that APs but no led is lid.
When i get closer to the AP i saw a Red color which can not be seen from distance (Not Red flashing LED).What the possible error can be ? Is it a factory default mistake or so ?
Hi, maybe LEDs on APs are disabled?
You cant try to use this command on your WLC:
  • (Cisco Controller) >config ap led-state enable
Or if you need to disable LED, use :
  • (Cisco Controller) >config ap led-state disable all
5 Replies 5
Leo Laohoo
Solid Green = WAP has booted up fine and has joined controller.  No user has associated this WAP.
Solid BLUE = Same as above except at least ONE user have associated this WAP.  Associated and authenticated are NOT the same.
Blinking = WAP is booting
RED = Hardware fault
The problem is , AP doesnt give out any lights.LED doesnt light on.
But from the controller ; i saw AP is operating , and i can connect on it.
Here is output of booting AP that can successfully join the contoller , and this is happening in more than one AP
*Mar  1 00:00:08.073: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:08.085: *** CRASH_LOG = YES
Security Core found.
Base Ethernet MAC address: FC:99:47:D5:39:C6
*Mar  1 00:00:09.661: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:10.233: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:10.264: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 16 messages)
*Mar  1 00:00:10.287:  status of voice_diag_test from WLC is false
*Mar  1 00:00:11.330: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.411: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:12.449: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1140 Software (C1140-K9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 14:52 by prod_rel_team
*Mar  1 00:00:12.449: %SNMP-5-COLDSTART: SNMP agent on host HR-Test is undergoing a cold start
*Mar  1 00:11:32.043: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar  1 00:11:32.110: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:11:32.110: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:11:33.110: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:11:33.110: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:11:33.303: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:11:41.233: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 172.16.78.207, mask 255.255.248.0, hostname HR-Test
*Mar  1 00:11:50.911:  status of voice_diag_test from WLC is false
*Mar  1 00:11:50.972: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:11:52.367: %CDP_PD-4-POWER_OK: Full power - LOW_POWER_CLASSIC_NO_INJECTOR_CONFIGURED inline power source
*Mar  1 00:11:52.390: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:11:52.415: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:11:53.374: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:11:53.375: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:11:53.401: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
Translating "CISCO-CAPWAP-CONTROLLER.dpu.edu.tr"...domain server (194.27.43.17) [OK]
*Mar  1 00:12:02.006: %CAPWAP-5-DHCP_OPTION_43: Controller address 172.16.64.10 obtained through DHCP
wmmAC status is FALSE
*Dec 10 14:03:03.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.64.10 peer_port: 5246
*Dec 10 14:03:03.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Dec 10 14:03:03.836: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.64.10 peer_port: 5246
*Dec 10 14:03:03.837: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.64.10
*Dec 10 14:03:03.837: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Dec 10 14:03:03.983: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Dec 10 14:03:04.100: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec 10 14:03:04.114: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec 10 14:03:04.114: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Dec 10 14:03:04.115: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 10 14:03:04.166: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller DPU_WIFI_KONTROLLER
In 7.0.220.0 version there is not color led enable / disable on the GUI.
I dont know why but something made the APs leds turn off.I have tested more than 5 of them some of thems operate properly with LEDs but some of turned off by default.
But at least this command has solved it.Thanks.
That is a good news to hear!
