1200 wireless AP utilization
ngyps
Community Member
Can anyone advise the 1200 AP is working fine, in term of CPU utilization, bandwidth utilization, client congestion, AP load handling?
Shawn
robert.wright
Level 5
Level 5
if your running WLSE you can check all your APs via the Faults tab, then click on 'Display Faults'
Heres some commands for ya 🙂
show dot11 associations
show interfaces dot11Radio X statistics (replace X with radio you want)
show processes cpu history
show memory statistics history
