1231G
serg_russ
Community Member
on "sh logg" command
- Sep 1 11:59:40: dot11_mgmt: bad cookie returned from driver for mac 0013.4661.9792(expected 0x00000000, got 0x00BFE150) - force driver to delete client
What is it?
Client DWL-G520 WindowsXP.
Other clients work normal
ivillegas
Level 11
Level 11
This might be due to interoperability . Locate and disable the Aironet Extension. Locate Radio preamble and set to long. Also try upgrading the client adpater version.
But other clients have a same Win XP and drivers version as this client, and signal strength level (
